Home » Language IDEs » Java Development Tools (JDT) » Maven not working with proxy in Eclipse
Maven not working with proxy in Eclipse [message #1737210] Wed, 06 July 2016 08:47 Go to next message
I'm trying to use Maven with Eclipse, but I have some trouble getting it to work with my proxy.
I installed Maven in C:\maven and I configured my proxy in C:\maven\conf\settings.xml and in C:\Users\[myusername]\.m2\settings.xml.
After some adjustments, I managed to get it working. Using maven from command line, everything seems to work (creating a project, downloading archetypes from the repository), so I suppose there is no problem here.
In Eclipse (I tried jee-mars and jee-neon), I changed the settings to point to the correct maven install path and settings.xml files.
Then, when trying to add a remote archetype catalog (http ://repo.maven.apache.org/maven2/archetype-catalog.xml), I get the message "Remote catalog is empty". When I try to create a new Maven project and click the button "Add Archetype...", I get an error like this one : "Can't resolve Archetype com.vaadin:vaadin-archetype-application:LATEST
org.eclipse.core.runtime.CoreException: Could not resolve artifact com.vaadin:vaadin-archetype-application:pom:LATEST".
I also tried to set the proxy settings in Eclipse (as "Native" or as "Manual"), but still maven doesn't work.
I used Wireshark to see what happens when I try to add the remote catalog, and I see it tries to do DNS requests directly to repo.maven.apache.org, instead of sending HTTP requests through the proxy.
So...
- Proxy settings in Eclipse are working fine (I can install plugins for example)
- Proxy settings in Maven (from command line) are working fine
- Proxy settings in Maven inside Eclipse are not working.
Can you help me please ?
Thanks.
Jean.
Re: Maven not working with proxy in Eclipse [message #1737379 is a reply to message #1737210] Thu, 07 July 2016 12:30 Go to previous messageGo to next message
Sounds like a question to the m2e experts. See here on how to contact them: https://www.eclipse.org/m2e/m2e-community.html
Re: Maven not working with proxy in Eclipse [message #1821976 is a reply to message #1737210] Mon, 24 February 2020 21:25 Go to previous messageGo to next message
I have the same exact issue with Eclipse 2019-12. The embedded maven does not take the proxy settings defined in the settings.xml and the global network settings. I spent a lot of time trying to resolve but nothing helps.
Building outside Eclipse works fine.
Please let me know if you resolved the issue.
Thank you.
Re: Maven not working with proxy in Eclipse [message #1822012 is a reply to message #1821976] Tue, 25 February 2020 11:34 Go to previous message
This is not a JDT question, but a question to the m2e experts. See here on how to contact them: https://www.eclipse.org/m2e/m2e-community.html
Previous Topic:Mark code blocks in different colours ?
Next Topic:JavaFx install error
Current Time: Sun Jul 27 16:13:40 EDT 2025
Powered by FUDForum. Page generated in 0.04447 seconds
