Home » Eclipse Projects » Memory Analyzer » Get list_objects in a custom mat report (Memory analyzer:Custom reports- get html report)
Get list_objects in a custom mat report [message #1821642] Tue, 18 February 2020 01:32 Go to next message
Hello, I am trying to generate a HTML viewable report using the ParseHeapDump.bat file. I am able to the suspect , overview and top components report. I need to be able to browse the list_objects properties of the suspects in the same tree manner that is shown in the GUI (see image 1&2).
I tried to run it as a query like this:
query name="Dominator Tree">
		<command>dominator_tree</command>
		<command>list_objects</command>
</query>
This causes an error to be thrown which says parameter objects is required for list_objects. I have no idea how to pass this parameter, for example for java.lang or some other suspects. Please advice
Thanks!
  • Attachment: img1.png
    (Size: 178.06KB, Downloaded 640 times)
  • Attachment: img2.png
    (Size: 254.03KB, Downloaded 149 times)
Re: Get list_objects in a custom mat report [message #1821832 is a reply to message #1821642] Thu, 20 February 2020 15:19 Go to previous messageGo to next message
There is not a way to do this directly from the leak suspects report.
The list_objects command expects object addresses or class names or patterns or an OQL query but there isn't a way to extra that from the leak suspects report to add to a new report. To test the command line then use OpenQuery Browser > Search Queries to bring a up a command line where you can type:
list_objects 0x12345678
or
list_objects java.lang.*
If there isn't enough information in the report and it seems a general problem then in a future release we could enhance the suspect report.
I suppose you could parse the report yourself and run a new report with the extracted information. See https://wiki.eclipse.org/MemoryAnalyzer/Extending_Memory_Analyzer#Reports_in_Memory_Analyzer for how to write reports. You can pass in command line parameters as
-myparm=myvalue
which can then be read using
${myparm}
in the XML of a new report definition.
Re: Get list_objects in a custom mat report [message #1821915 is a reply to message #1821832] Sat, 22 February 2020 16:37 Go to previous messageGo to next message
I have made some changes under bug 287952 which should improve a leak suspect report for the particular situation in the example below and and give a list of those objects in the biggest instance list and a better reference pattern.
https://www.eclipse.org/forums/index.php?t=getfile&id=37394
Please give the latest snapshot build a try.
Re: Get list_objects in a custom mat report [message #1821938 is a reply to message #1821915] Mon, 24 February 2020 00:22 Go to previous message
Thank you for the response Andrew. I'll try the snapshot build and also the custom reports method to try to get it to work.
Previous Topic:Query: Group By Value shows no values
Next Topic:Retained heap calculated incorrectly in dominator tree?
Current Time: Wed Nov 05 14:37:26 EST 2025
Powered by FUDForum. Page generated in 0.03455 seconds
