Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » ECC status change Hook executeEvent
ECC status change Hook executeEvent [message #1821868] Fri, 21 February 2020 07:07 Go to next message
sometimes we have the problem that there are many statuses
in the custom FB, and we want to all the current status where meet the
condition then will route to one status(for example:Stopped),
we need do something at the beginning of the executeEvent, or the end of the excuteEvent. Which is very useful, otherwise the lines will be too many.
Re: ECC status change Hook executeEvent [message #1821869 is a reply to message #1821868] Fri, 21 February 2020 07:16 Go to previous messageGo to next message
that's currently outside the modelling methods of IEC 61499
Re: ECC status change Hook executeEvent [message #1821879 is a reply to message #1821869] Fri, 21 February 2020 09:45 Go to previous messageGo to next message
What I found very helpfull is to have several algorithms to be used in one action. I think this is not what you wanted but it may help you.
Re: ECC status change Hook executeEvent [message #1821882 is a reply to message #1821879] Fri, 21 February 2020 10:26 Go to previous messageGo to next message
@Mr. Zoitl,
not exactly what i want ,
for example, i want the functionality as the bold lines:
once meet the condition, whatever status then route to Stopped status
now if there are 20 status, we have to connect each status to Stopped status 20 times. that makes the GUI difficult to view and check
void FORTE_LightCylinder::executeEvent(int pa_nEIID){
bool bTransitionCleared;
do{
bTransitionCleared = true;
if((Stop() == 1) || (((Automode() == 0) && (Rst() == 1))))
enterStateStop();
switch(m_nECCState){
case scm_nStateSTART:
if((scm_nEventONID == pa_nEIID) && (((LScreen() == 1) && (Stop() == 0))))
enterStateForwarding();
else
if((scm_nEventREQID == pa_nEIID) && ((Stop() == 1)))
enterStateStop();
else
bTransitionCleared = false; //no transition cleared
break;
case scm_nStateForwarding:
enterStateStop();
else
if((LCLimit() == 1) && (LScreen() == 1))
enterStateLimit();
else
break;
case scm_nStateLimitOperation:
if((scm_nEventOffID == pa_nEIID) && (((LScreen() == 1) && (Stop() == 0))))
enterStateBacking();
else
enterStateStop();
else
break;
case scm_nStateBacking:
if((LCOrigin() == 1) && (((Automode() == 1) || (((Automode() == 0) && (Jog() == 1))))))
enterStateBackingLimit();
else
enterStateStop();
else
break;
case scm_nStateBackingLimit:
if(1)
enterStateSTART();
else
enterStateStop();
else
break;
case scm_nStateStop:
if(Stop() == 0)
enterStateSTART();
else
break;
case scm_nStateLimit:
if((((Automode() == 1) || (((Automode() == 0) && (Jog() == 1))))) && (LScreen() == 1))
enterStateLimitOperation();
else
enterStateStop();
else
break;
default:
DEVLOG_ERROR("The state is not in the valid range! The state value is: %d. The max value can be: 6.", m_nECCState.operator TForteUInt16 ());
m_nECCState = 0; //0 is always the initial state
break;
pa_nEIID = cg_nInvalidEventID; // we have to clear the event after the first check in order to ensure correct behavior
}while(bTransitionCleared);
[Updated on: Fri, 21 February 2020 10:33] by Moderator
Re: ECC status change Hook executeEvent [message #1821918 is a reply to message #1821882] Sat, 22 February 2020 16:57 Go to previous messageGo to next message
Thanks for the clarification. Yes my suggestion is of no help in your case.
What would help in your case would be hierarchical state machines. Hierarchical state machines are currently not in the definitions of the standard. However we are discussing that in the standardization committee to expand the standard with them.
Re: ECC status change Hook executeEvent [message #1821924 is a reply to message #1821918] Sun, 23 February 2020 03:01 Go to previous messageGo to next message
When will it be opened? And is this in the develop version?
[Updated on: Sun, 23 February 2020 03:25] by Moderator
Re: ECC status change Hook executeEvent [message #1821934 is a reply to message #1821924] Sun, 23 February 2020 10:11 Go to previous message
I can not say. We first need the definitions in the standard before we can start implementing something for Eclipse 4diac.
Previous Topic:Does FORTE run on systems without OS
Next Topic:How does 4diac convert ST into c code?
Current Time: Wed Jul 30 19:22:47 EDT 2025
Powered by FUDForum. Page generated in 0.08046 seconds
