[CDO] Repository initialization for mysql databse backend [message #1821822] |
Thu, 20 February 2020 10:56  |
We (successfully) used the mysql datbase backend with the following cdo version:
<unit id="org.eclipse.emf.cdo.sdk.feature.group" version="4.5.0.v20160607-1511"/>
<unit id="org.eclipse.net4j.db.mysql.feature.group" version="4.2.300.v20160301-1326"/>
<unit id="org.eclipse.net4j.feature.group" version="4.5.0.v20160607-1254"/>
Now, we updated to this version:
<unit id="org.eclipse.emf.cdo.sdk.feature.group" version="5.0.0.v20180530-1201"/>
<unit id="org.eclipse.net4j.db.mysql.feature.group" version="4.2.500.v20180529-1130"/>
<unit id="org.eclipse.net4j.feature.group" version="4.7.0.v20180530-1201"/>
Since then, I am not able to start a repository.
It fails with this stacktrace:
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.removeClassMapping(AbstractMappingStrategy.java:561)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.mapClasses(AbstractMappingStrategy.java:533)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.mapPackageInfos(AbstractMappingStrategy.java:515)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.mapPackageUnits(AbstractMappingStrategy.java:502)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.removeMapping(AbstractMappingStrategy.java:490)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.doRollback(DBStoreAccessor.java:809)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.rollback(StoreAccessorBase.java:189)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.rollback(TransactionCommitContext.java:1362)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.handleException(TransactionCommitContext.java:808)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:746)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:49)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:95)
at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:1206)
at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:1199)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:316)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:102)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:118)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:87)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:100)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:380)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:73)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:286)
at org.eclipse.net4j.signal.Signal.run(Signal.java:165)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Could this be a bug, or do I need to change some configuration?
FUDForum. Page generated in 0.08667 seconds
