Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » trace running log
trace running log [message #1821793] Thu, 20 February 2020 03:54 Go to next message
I am running the forte on the raspberry( a bit smiliar like the exmaple FestoMPS) and with modbus,
i used the default modbus not ng-moduble, because mine is RTU,
the machine had been running for several hours then it stopped,
how can i trace where the problem is ?
use what component to write the log ? avoid frequent I/O cauing performance problem?
[Updated on: Thu, 20 February 2020 04:34] by Moderator
Re: trace running log [message #1821835 is a reply to message #1821793] Thu, 20 February 2020 15:45 Go to previous message
You could try running it with gdb. Maybe you get some debug output from gdb (e.g., segfault).
Previous Topic:Convert decimal to binary format with ST
Next Topic:Comparing negative values
Current Time: Thu Jul 31 00:50:32 EDT 2025
Powered by FUDForum. Page generated in 0.04600 seconds
