Using Xtext DSL as a rule engine on runtime [message #1821429] |
Wed, 12 February 2020 17:26  |
Dear Xtext experts,
Thanks a lot for such an awesome technology and tools built around it!
We are using an Xtext technology to build a custom DSL which allow us to use different conditions as part of a rule engine and get a result of such conditions by running a DSL interpreter on runtime.
Example of such condition is here:
if(doSomething()) {
return true;
} else {
return false;
To run an interpreter we just create a model from our string conditions, load it as resource, get model and run interpreter.
Here it's a way we create and load our resource with a condition string:
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
resourceSet.createResource(URI.createURI(UUID.randomUUID().toString());
InputStream inputStream = new ByteArrayInputStream("condition as string");
resource.load(inputStream, resourceSet.getLoadOptions());
Could you help me with the following questions:
1. Do we use a ResourceSet in a proper way? Maybe some pieces of advice?
2. Do you see any possible issues (out of memory, timings etc)
Thanks in advance!
Re: Using Xtext DSL as a rule engine on runtime [message #1821706 is a reply to message #1821568] |
Tue, 18 February 2020 15:55  |
Adding to Christians comments
You could just do - XtextResourceSet resourceSet = new XtextResourceSet()
ECoreUtil#resolveAll() gets called internally, which tries to resolve all the proxies in your model. It might not be a good idea to load the complete model in the memory right at the start, especially if its a deep hierarchy
The file extension in the URI is required for getting the Resource Factory. It needs to be registered if you are running your application in standalone mode
resource.load(new StringInputStream("condition as string"));
Hope this helps.
FUDForum. Page generated in 0.05499 seconds
