cdt.parser for GNU GCC error [message #1821633] |
Mon, 17 February 2020 17:43  |
Runs on CentOS 7 Linux using MobaXterm on Windows 10 for remote access.
* This had been working. I don't know what is causing it to malfunction.
* I've recovered a previous version of my project's .cproject file.
* I've been reviewing the various settings in ~/.eclipse in an attempt to remove and regenerate configuration files.
* I am about to rename the entire ~/.eclipse folder.
* Where else can a configuration setting cause such an error?
* I suggest as an alternative to double clicking having a menu item in the drop down menu which performs the same activity.
* My next course of action would be to review the code. The last time I tried that it was impossible to follow the code logic due to all the indirection resulting from calls to the Java interfaces.
For someone who is not familiar with the CDT code I would really need to have a Java debugging environment setup so you can look at the concrete object types. Getting that working seems a lot of effort.
FUDForum. Page generated in 0.04969 seconds
