Home » Eclipse Projects » Sirius » "element" bug in Reconnect Edge
"element" bug in Reconnect Edge [message #1821295] Mon, 10 February 2020 09:26 Go to next message
According to https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html:
source: the semantic element which is pointed before the reconnect.
target: the semantic element which is pointed after the reconnect.
element: the semantic element of the current edge.
When I access the source.name and target.name I get the name of the correct elements. However, when I try to access element.name (an attribute which exists for the element represented by the edge) it appears blank.
Is this a bug or am I doing something wrong?
A bit about the use case: my edge is an element based edge, which points to the source (element.source) and destination (element.dest). I want to allow the user to change the element.source to a new source by using the "reconnect edge" tool - moving the source from source1 to source2 (so that if element.source was "source1" it will become "source2" instead).
I manage to do it successfully, but if I use an "open dialog" and use element.name it returns an empty string as opposed to source.name and target.name.
Thank you,
Avi
[Updated on: Mon, 10 February 2020 09:37] by Moderator
Re: "element" bug in Reconnect Edge [message #1821305 is a reply to message #1821295] Mon, 10 February 2020 10:20 Go to previous messageGo to next message
I checked and added a "Set" operation to change the name of the element I was reconnecting without issue. How did you compose the model operation of your tool? Do you have a "Change context" operation with the expression var:element beforehand?
Steve
Re: "element" bug in Reconnect Edge [message #1821306 is a reply to message #1821305] Mon, 10 February 2020 10:23 Go to previous messageGo to next message
No. I only used an open dialog tool, and tried to display the name by using "aql: element.name". It did not work, but "aql: source.name" and "aql: target.name" did work. Any reason for this? Since these are all semantic entities, I imagined they should behave the same when referenced.
Re: "element" bug in Reconnect Edge [message #1821311 is a reply to message #1821306] Mon, 10 February 2020 11:25 Go to previous messageGo to next message
Ah ok, I thought the issue was with changing the name at first.
I set the title expression of the "open dialog" operation as "aql:element.name" and the name was properly displayed in the Dialog title area. Where did you placed this expression?
Steve
Re: "element" bug in Reconnect Edge [message #1821349 is a reply to message #1821311] Tue, 11 February 2020 06:29 Go to previous message
I actually placed it someplace else, but now tried it in the title area (like to suggested), and the title remains blank (unlike when using source.name or target.name). I am using Obeo 11.1.2.
Thanks anyway for attempting to solve this. It is not crucial for me. Since you cannot reproduce it, I will not open a bug.
Avi
Previous Topic:Bug report - Note gets detached when reconnecting edges
Next Topic:Does org.eclipse.sirius.diagram.customBundledImageShape work?
Current Time: Sat Jul 26 00:40:33 EDT 2025
Powered by FUDForum. Page generated in 0.03893 seconds
