Home » Newcomers » Newcomers » Mistake
Mistake [message #1818700] Mon, 23 December 2019 19:13 Go to next message
Opens the dialog with the following message: could not start Goclipse because Java version is: 0 version 8 is required, can anyone help me solve?
Re: Mistake [message #1818704 is a reply to message #1818700] Tue, 24 December 2019 00:55 Go to previous messageGo to next message
It's probably best to ask on the Goclipse forum:
https://groups.google.com/forum/#!forum/goclipse
Note that this project is not an Eclipse-hosted project so it's hard to help with problems specific to Goclipse...
Re: Mistake [message #1820979 is a reply to message #1818704] Mon, 03 February 2020 13:32 Go to previous messageGo to next message
For what it's worth, it looks like goClipse has been abandoned since 2017 and it even appears like it is no longer supported.
I tried installing goClipse with Eclipse version 2019-12 and it appeared like it was just a shell for the user interface. All the default "tools" under it's preferences were blank/empty when the documentation appears to suggest there should be something there as installed by default.
I also followed the provided link from above, and the developer states they are no longer supporting it.
I'm just curious, if a plugin has not been active since 2017, how are us end users supposed to know? I guess marketplace does not filter by compatibility? Or someone is just blindly marking goClipse as compatible? It looks like there were a large number of downloads through market place, but I'm having serious doubts that most of those downloads resulted in a functional product? It would be nice if market place also showed the number of uninstalls too, or perhaps a way to indicate that it does not work?
The bottom line here is that goClipse would not work for me with Eclipse version 2019-12, and with it being abandoned back in 2017, I don't think its worth trying to manually force it to work. Go is a life and thriving language, so there has to be something out there to better support the newer constructs and dynamics of the current golang releases.
Re: Mistake [message #1820982 is a reply to message #1820979] Mon, 03 February 2020 20:45 Go to previous messageGo to next message
It might be more about the version of Java running Eclipse than anything to do with Eclipse itself. This message looks familiar... Try it again with Java 8.
[Updated on: Mon, 03 February 2020 20:45] by Moderator
Re: Mistake [message #1820986 is a reply to message #1820982] Tue, 04 February 2020 00:43 Go to previous messageGo to next message
Looking at this listing, it doesn't look totally dead because it's been recently updated:
https://marketplace.eclipse.org/content/goclipse
We (the royal we, as in I) do test whether listings can be successfully installed:
https://www.eclipse.org/setups/marketplace/?id=686976
But only the authors (users) test whether it actually works well.
The listing's home link navigates to this:
http://goclipse.github.io/
But the forum does look pretty dead...
Re: Mistake [message #1836994 is a reply to message #1818700] Wed, 20 January 2021 13:37 Go to previous message
I finally found something on this. I was able to resolve it by deleting the jvmcheck file. Here is the link to the ticket.
https://github.com/GoClipse/goclipse/issues/256
Your file name may be slightly different. I did a search for "jvmcheck" and deleted the one file that showed up.
It's too bad this plugin was abandoned. I wish someone would take up the mantle; it seems like a popular plugin.
Previous Topic:Eclipse is damaged while installing RTC602
Next Topic:Eclipse HelloWorld program not working. Error: Could not find or load main class HelloWorld Caused b
Current Time: Mon Jul 21 07:29:05 EDT 2025
Powered by FUDForum. Page generated in 0.30266 seconds
