Home » Language IDEs » C / C++ IDE (CDT) » cout and console control characters (FYI 2019-12 )
cout and console control characters [message #1820963] Mon, 03 February 2020 10:17 Go to next message
The attached C++ code produces UNEXPECTED results - using standard local GCC Linux
1. Extra line added after each <<end;
2.The ASCII control characters are ignored
Preferences -> Debug -> Console
"interpret ASCII control characters " IS SET
The above all works as expected using cross-complied Linux "arm-..."
	cout << " START test area go " << __LINE__<< endl;
	cout << __FUNCTION__ << endl;
	cout << " START test area " << __LINE__ << endl;
	cout << "\033[1;31mbold red text\033[0m\n";
	cout << "\033[1;32mbold green text\033[0m\n";
 START test area go 16main
 START test area 19
main
 START test area 21
main
bold red text
bold green text
Re: cout and console control characters [message #1820978 is a reply to message #1820963] Mon, 03 February 2020 13:26 Go to previous message
from the help for 2019-12
Interpret ASCII control characters
This preference will enable interpretation of some ASCII control characters in console. So far console can interpret backspace (\b) and carriage return (\r) if enabled. (see next preference for additional option on carriage return)
Note that it says ASCII and not ANSI
There is a difference.
Even if it were ANSI , the control set depends on the type of terminal being emulated.
The controls you tried to use are more appropriate for VT100 emulation.
The out-of-the box Eclipse console does not support ANSI emulation.
[Updated on: Mon, 03 February 2020 13:31] by Moderator
Previous Topic:Code Folding Problems
Next Topic:code with eclipse
Current Time: Thu Jul 24 07:34:08 EDT 2025
Powered by FUDForum. Page generated in 0.05802 seconds
