Home » Eclipse Projects » Eclipse Scout » Update Table Header Text after Smart field value Change
Update Table Header Text after Smart field value Change [message #1820943] Sun, 02 February 2020 16:07 Go to next message
Hello All,
I need to change the table header text based on a value change of a smart field.
How can I access the header texts and update the UI after the change event.
Re: Update Table Header Text after Smart field value Change [message #1820950 is a reply to message #1820943] Mon, 03 February 2020 03:23 Go to previous messageGo to next message
For some reason this is quite complicated, but this will work:
Table table = getTableField().getTable();
NameColumn column = table.getNameColumn();
((HeaderCell) column.getHeaderCell()).setText("Text from SmartField");
TableEvent event = new TableEvent(table, TableEvent.TYPE_COLUMN_HEADERS_UPDATED);
event.setColumns(table.getColumns());
table.fireTableEventInternal(event);
By sending the event COLUMN_HEADERS_UPDATED the UI will re-render the table-header (and only the table-header).
André
Re: Update Table Header Text after Smart field value Change [message #1820980 is a reply to message #1820950] Mon, 03 February 2020 14:31 Go to previous message
That is perfect, thanks
[Updated on: Mon, 03 February 2020 14:32] by Moderator
Previous Topic:Uploading all files in a directory tree in Scout 9
Next Topic:Aggregating columns in a table according to a different algorithm than the one built-in
Current Time: Fri Aug 29 18:22:55 EDT 2025
Powered by FUDForum. Page generated in 0.06458 seconds
