| WSDL user group [message #181688] |
Tue, 17 October 2006 12:09  |
Originally posted by: spruitt.exstream.com
Can someone recommend a WSDL user / mailing group? I can't seem to locate
one by searching.
I'm have WSDL validation errors I don't understand and I am looking for an
appropriate list to gather some advice.
Thanks.
-S
| Re: WSDL user group [message #182096 is a reply to message #182088] |
Thu, 02 November 2006 15:55  |
Originally posted by: valentinbaciu.hotmail.com
Steve, here's a suggested workaround.
The broken MIME schema is contributed to the XML catalog by the org.wsdl4j
plug-in. You should be able to override it by specifying a user catalog
entry pointing to the new schema. So download the new schema from the URL I
mentioned below then go to Preferences/Web and XML/XML Catalog, select the
User Specified Entries and click Add. In the dialog browse to the location
where you placed the downloaded schema, specify namespace name as the key
and enter the proper namespace in the namespace field. Click OK and save the
preferences and you should be all set. Try re-validating your file: the
error should go away. I've attached a picture showing the end result of
adding the new schema to the catalog.
Valentin
"Steve Pruitt" <spruitt@exstream.com> wrote in message
news:eidblg$c2g$1@utils.eclipse.org...
> Thanks for your help. I have been on the road for a bit, so I am late
> getting back to you. Looking at the comments in the defect to track it,
> it
> looks like a fix is not coming anytime soon.
> I am not sure how I can resolve until a fix shows up. I look at the
> validator preference properties and nothing jumped out at me. Can I
> directly import the updated schema into my wsdl?
> -S
> "Valentin Baciu" <valentinbaciu@hotmail.com> wrote in message
> news:eh5cni$imd$1@utils.eclipse.org...
> Thanks for the sample and details Steve - they did help me find the cause.
> It appears the WSDL validator is "correct" based on the MIME binding
> schema
> it has. Problem is that schema is wrong.
> The WS-I Attachements Profile has corrected this schema. See
> http://www.ws-i.org/Profiles/AttachmentsProfile-1.0.html#MIM E_Binding_Schema_Fixes
> I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=161410 to track
> this issue. Feel free to add yourself as CC to the bug if you have a
> bugzilla account.
> Regards, Valentin
> news:eh56bo$6rt$1@utils.eclipse.org...
>> Sorry, Valentin. I thought the bare minimum would be enough. The
>> versions
>> are Eclipse 3.2.1 and the WTP is 1.5.1-200609230508.
>> The error message is:
>> Severity and Description Path Resource Location Creation Time Id
>> cvc-complex-type.2.4.a: Invalid content was found starting with element
>> 'soap:body'. One of '{WC["http://schemas.xmlsoap.org/wsdl/mime/"]}' is
>> expected. EWS-WSDL/src EngineServices.wsdl line 66 1161118698302 266
>> and, finally the full wsdl:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <definitions xmlns="http://schemas.xmlsoap.org/wsdl/"
>> xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
>> xmlns:mime="http://schemas.xmlsoap.org/wsdl/mime/"
>> xmlns:exst="urn:beta-services" targetNamespace="urn:beta-services">
>> <types>
>> <xsd:schema>
>> <xsd:element name="PreviewRequest">
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:element name="PubFile" type="xsd:string" maxOccurs="1"
>> minOccurs="1"/>
>> <xsd:element name="Driver" maxOccurs="1" minOccurs="1">
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:any namespace="##local" processContents="skip"
>> maxOccurs="unbounded" minOccurs="0"/>
>> </xsd:sequence>
>> <xsd:attribute name="filename" type="xsd:string"
>> use="optional"
>> default="INPUT"/>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> <xsd:attribute name="includeheader" type="xsd:boolean" use="optional"
>> default="false"/>
>> </xsd:complexType>
>> </xsd:element>
>> <xsd:element name="PreviewResponse">
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:element name="PreviewHeaders">
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:element name="Version" type="xsd:integer" maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="PDL" type="xsd:integer" maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="OutputLength" type="xsd:integer" maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="MessageLength" type="xsd:integer"
>> maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="UserDataLength" type="xsd:integer"
>> maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="PageCount" type="xsd:integer" maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="ReturnCode" type="xsd:integer" maxOccurs="1"
>> minOccurs="0"/>
>> <xsd:element name="FileType" type="xsd:string" maxOccurs="1"
>> minOccurs="0"/>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:schema>
>> </types>
>> <message name="getPreviewRequest">
>> <part name="Document" element="exst:PreviewRequest"/>
>> </message>
>> <message name="getPreviewResponse">
>> <part name="Document" element="exst:PreviewResponse"/>
>> <part name="Content" type="xsd:base64Binary"/>
>> </message>
>> <portType name="PreviewReportPortType">
>> <operation name="compose">
>> <input name="PreviewRequest" message="exst:getPreviewRequest"/>
>> <output name="PreviewResponse" message="exst:getPreviewResponse"/>
>> </operation>
>> </portType>
>> <binding name="PreviewReportBinding" type="exst:PreviewReportPortType">
>> <soap:binding transport="http://schemas.xmlsoap.org/soap/http"
>> style="document"/>
>> <soap:operation soapAction="urn:beta-service"/>
>> <input>
>> <soap:body use="literal"/>
>> </input>
>> <output>
>> <mime:multipartRelated>
>> <mime:part name="headers">
>> </mime:part>
>> <mime:part name="preview">
>> <mime:content part="Content" type="text/binary"/>
>> </mime:part>
>> </mime:multipartRelated>
>> </output>
>> </operation>
>> </binding>
>> <service name="EngineService">
>> <port name="EngineServicePort" binding="exst:PreviewReportBinding">
>> <soap:address
>> location="http://localhost:9080/beta/services/EngineService"/>
>> </port>
>> </service>
>> </definitions>
Attachment: pic.JPG
(Size: 53.30KB, Downloaded 208 times)
FUDForum. Page generated in 0.04400 seconds
