Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4Diac-Arrowhead framework (Arrowhead Function Blocks)
4Diac-Arrowhead framework [message #1820740] Tue, 28 January 2020 03:52 Go to next message
Hi All,
How can we GET a service from Arrowhead Framework,that is already registered there?
For example, https://localhost:port/serviceregistry/mgmt/22.,
which Functions blocks can be utilized?
I have been using the following approach.
Please also point me towards any new documentations.
Thanks in advance.
BR,
Ahsan
  • Attachment: Capture.JPG
    (Size: 418.97KB, Downloaded 108 times)
Re: 4Diac-Arrowhead framework [message #1820743 is a reply to message #1820740] Tue, 28 January 2020 04:48 Go to previous messageGo to next message
When using Arrowhead, the best practice is not to query the service yourself, but ask the orchestrator for the service. But for testing, of course you could query yourself.
The main documentation is here: https://www.eclipse.org/4diac/en_help.php?helppage=html/communication/arrowhead.html
At the end of the page, you have a link to examples: https://git.eclipse.org/c/4diac/org.eclipse.4diac.examples.git
The easiest way I'd say is to use "QueryServiceHTTPSubFull" which has all the fields to be defined by you. You should take care of the types of the data input/ouput. CHeck the type and the description of the inputs and outputs. The output for example is an array of ServiceRegistryEntry. You could get the specific position of an array using the FB called GET_AT_INDEX and then like you did, use GetEndpointFromServiceRegistryEntry to get the endpoint (IP:PORT/URI). How you use this endpoint, depends on your application. If this is for example an HTTP endpoint, then you should check the HTTP layer for forte, and build the ID string for the CLIENT FB.
Re: 4Diac-Arrowhead framework [message #1820813 is a reply to message #1820743] Wed, 29 January 2020 08:50 Go to previous messageGo to next message
Thank you. Looks like I am going in the right direction.
What should be the entries of the fields?
Using (IP:PORT/serviceregistry/mgmt/id) as address. The id is 22. primarily, using POSTMAN to register the services.
Registering the end point URL address of OPC UA for Client and publish blocks.
I am using this procedure to first test the application and if it works twill implement the orchestrator for the service (as you mentioned).
BR,
Ahsan
"id": 22,
"serviceDefinition": {
"id": 23,
"serviceDefinition": "valve102",
"createdAt": "2020-01-27 13:15:40",
"updatedAt": "2020-01-27 13:15:40"
"provider": {
"id": 14,
"systemName": "NAME",
"address": "iec61499",
"port": 0,
"authenticationInfo": "string",
"createdAt": "2020-01-27 12:35:27",
"updatedAt": "2020-01-27 12:35:27"
"serviceUri": "opc_ua[opc.tcp://localhost:IP#/Objects/2:PLC1/2:eq_states/2:EQ_V102]",
"secure": "NOT_SECURE",
"metadata": {},
"version": 0,
"interfaces": [
"id": 3,
"interfaceName": "HTTPS-SECURE-JSON",
"createdAt": "2019-12-27 06:45:42",
"updatedAt": "2019-12-27 06:45:42"
  • Attachment: Arrowhead.JPG
    (Size: 325.64KB, Downloaded 80 times)
Re: 4Diac-Arrowhead framework [message #1820814 is a reply to message #1820813] Wed, 29 January 2020 09:03 Go to previous messageGo to next message
the data input "interfaces" is an array, so it should be
["HTTPS-SECURE-JSON"]
The address should just be:
The FB will query then for services called "valve102"
Also, it looks that you're using version 4.1.3 of the AF. The implementation in 4diac is not compatible with 4.1.3, only with 4.1.2. I assume you read the documentation
Re: 4Diac-Arrowhead framework [message #1821077 is a reply to message #1820814] Wed, 05 February 2020 04:57 Go to previous messageGo to next message
Thank you.
I only had 4.1.3 running at the moment, but trying to put up 4.1.2.
Is it required to run two separate FORTE run-time instances in 4Diac, one connecting Arrowhead to 4Diac and second connecting 4Diac to control application Application using OPC UA? Or work by compiling the FORTE with open62451 with the arrow module enabaled?
Is this the right way to declare endpoint?
Please check the previous comment for complete message body.
Best
  • Attachment: Forum.JPG
    (Size: 200.59KB, Downloaded 82 times)
Re: 4Diac-Arrowhead framework [message #1821100 is a reply to message #1821077] Wed, 05 February 2020 10:58 Go to previous messageGo to next message
Hi Ahsan,
you can definitely have everything in one forte. As for the second point, I believe serviceUri is an arrowhead-specific identifier, i don't think it should follow 4diac notations :-) in short: i think, you can have there whatever you want, it'll only be seen in the arrowhead database. @Jose, correct me, if i'm wrong.
Kirill
Re: 4Diac-Arrowhead framework [message #1821140 is a reply to message #1821100] Thu, 06 February 2020 04:42 Go to previous message
HI,
the serviceUri refers to the part after the endpoint separated by a slash. So you normally have IP:PORT/SERVICE_URI. It's basically the information you need to access the specific service inside the device.
In OPC UA you could thing as being Objects/PLC/eq_states/EQ_V102. But since you need the namespace of the browsename, you could put there "#/Objects/2:PLC1/2:eq_states/2:EQ_V102", that means that the client consuming this service should know what the numbers means, but since it's you for now, no problems there.
When you query for the service, there's a subapplication called GetEndpointFromServiceRegistryEntry.sub and other similars FBs/SUBs which takes the ServiceRegistryEntry and gives you IP:PORT/SERVICE_URI (yes, also the serviceUri) which you will need then to concatenate to form the opc_ua[...] string that you need to consume the service.
Take a look at https://www.eclipse.org/4diac/en_help.php?helppage=html/communication/opc_ua_version1.html to know how the string should look
Previous Topic:LuaJit in windows in ok but under raspiberry can't
Next Topic:Stopping and starting FB applications under FORTE
Current Time: Sun Jul 27 04:42:03 EDT 2025
Powered by FUDForum. Page generated in 0.05694 seconds
