Home » Archived » Eclipse Communications Framework (ECF) » Broken JaxRs provider feature(Previous JaxRs provider version is referenced in ECF feature.xml)
Broken JaxRs provider feature [message #1819517] Thu, 16 January 2020 11:19 Go to next message
Hi all,
installing "ecf-rs-distribution-cxf" (from [https]://download.eclipse.org/rt/ecf/RELEASE/site.p2/karaf-features.xml) the process fails while downloading "[https]://raw.githubusercontent.com/ECF/JaxRSProviders/master/build/plugins/org.eclipse.ecf.provider.cxf.server_1.7.0.201902212132.jar", due to a 404. (Logs attached)
Checking in [https]://github.com/ECF/JaxRSProviders/tree/master/build/plugins the referenced version doesn't exists, instead the 1.8.2.201912081257 is present.
Any suggestion is appreciated :)
Thank you in advance!
Mattia
Re: Broken JaxRs provider feature [message #1819601 is a reply to message #1819517] Fri, 17 January 2020 15:29 Go to previous messageGo to next message
Mattia Barrasso wrote on Thu, 16 January 2020 11:19
Hi all,
Mattia
Hi Mattia,
Our apologies. We are moving to including this karaf repo in 3.14.7:
https://github.com/ECF/JaxRSProviders/blob/master/build/karaf-features.xml
This tutorial has been updated to use that repo:
https://wiki.eclipse.org/Tutorial:_JaxRS_Remote_Services_on_Karaf
for install of Jersey or CXF distribution providers.
In the existing version of ECF (3.14.6) we have/had the cxf features directly in the features.xml for the sdk here:
https://download.eclipse.org/rt/ecf/RELEASE/karaf-features.xml
In the 3.14.7 version, we will link to this repo:
so that users get the latest...but we are not quite done with 3.14.7. Apologies about that.
In the mean time, I think you should be able to install the latest for the JaxRS providers by using this repo URL:
to add/install the CXF features.
Also...if you want to keep up to date about the JaxRS providers...or download the latest release, please see:
Scott
Re: Broken JaxRs provider feature [message #1819602 is a reply to message #1819601] Fri, 17 January 2020 15:42 Go to previous messageGo to next message
Scott Lewis wrote on Fri, 17 January 2020 15:29
Hi all,
Mattia
Hi Mattia,
Scott
Just to be clear, this is the repo url you should use for the latest JaxRSProvider repo:
https://raw.githubusercontent.com/ECF/JaxRSProviders/master/build/karaf-features.xml
notice the raw.githubusercontent.com.
This is what is given in the tutorial:
Re: Broken JaxRs provider feature [message #1819661 is a reply to message #1819602] Mon, 20 January 2020 09:57 Go to previous message
Thank you Scott.
Currently we are conducing a spike over ECF & JaxRS provider, but in the long therm if everything works out we're planning to use them in production.
For this reason, leveraging on the ECF feature file that holds references to a master branch is not working. For example, all older versions of ECF (like https://download.eclipse.org/rt/ecf/3.14.3/karaf-features.xml) are broken.
Are you considering publishing the JaxRs artifacts to a p2 repository, or equivalent, in the near future?
Thank you for your time!
Mattia
Previous Topic:httpclient4 - Feature
Next Topic:@InjectLink
Current Time: Sat Nov 01 01:35:16 EDT 2025
Powered by FUDForum. Page generated in 0.05058 seconds
