Problem with installing plugins in Eclipse [message #1819538] |
Fri, 17 January 2020 01:11 |
i´ve some trouble with installing a plugin in Eclipse. I´m using Quartus Prime Lite Edition (v. 18.1) NIOS II EDS (Eclipse Mars.2 Release (4.5.2)). This is a customized version from Intel for fpga programming and i need the features of NIOS II EDS. So i cannot change the Eclipse version
My Problem:
When I try to install the plugin, it fails, because it could not find the installed requirements. When I tried to install via "Install New Software" or via command line, i get the following message:
C:\Users\maemeba>"C:\intelFPGA_lite\18.1\nios2eds\bin\eclipse_nios2\eclipsec.exe" -nosplash -application org.eclipse.equinox.p2.director -repository http://welding1.wittag.net:9090/axivion/axivion-eclipse-plugin/repository -installIU com.axivion.aclipse.feature.feature.group
Installing com.axivion.aclipse.feature.feature.group 6.9.13.02186.
Installation failed.
Cannot complete the install because one or more required items could not be found.
Software being installed: Axivion Eclipse Feature 6.9.13.02186 (com.axivion.aclipse.feature.feature.group 6.9.13.02186)
Missing requirement: Axivion Eclipse Feature 6.9.13.02186 (com.axivion.aclipse.feature.feature.group 6.9.13.02186) requires 'org.eclipse.equinox.p2.operations 2.1.0' but it could not be found
Application failed, log file location: C:\Users\maemeba\.altera.sbt4e\18.1.0.625-windows64\configuration\1579076958115.log
I´ve checked, if the missing requirements are aviable, and they are there.
FIY: The Eclipse can contact the URL.
Unfortunately the support for the Quartus product can't help me.
Do you know any solutions?
Many thanks
Kind regards
Bastian
FUDForum. Page generated in 0.05400 seconds
