problems contributing to DIAMETER_ProtcolModule_Generator / gerrit out of sync? [message #1819257] |
Fri, 10 January 2020 10:01  |
Hi!
I have a fix for the titan.ProtocolModules.DIAMETER_ProtocolModule_Generator documentation. However, when trying to push it to ssh://review.gerrithub.io:29418/eclipse/titan.ProtocolModules.DIAMETER_ProtocolModule_Generator, gerrithub refuses as follows:
> git push gerrit HEAD:refs/for/master 285/130/0
Enumerating objects: 275, done.
Counting objects: 100% (275/275), done.
Delta compression using up to 4 threads
Compressing objects: 100% (18/18), done.
Writing objects: 100% (153/153), 203.77 KiB | 22.64 MiB/s, done.
Total 153 (delta 136), reused 145 (delta 134)
remote: Resolving deltas: 100% (136/136)
remote: Processing changes: refs: 1, done
remote: ERROR: commit 9f33566: email address elemer.lelik@ericsson.com is not registered in your account, and you lack 'forge committer' permission.
remote: The following addresses are currently registered:
remote: laforge@gnumonks.org
remote: To register an email address, visit:
remote: https://review.gerrithub.io/settings#EmailAddresses
remote:
remote:
To ssh://review.gerrithub.io:29418/eclipse/titan.ProtocolModules.DIAMETER_ProtocolModule_Generator
! [remote rejected] HEAD -> refs/for/master (commit 9f33566: invalid committer)
error: failed to push some refs to 'ssh://laf0rge@review.gerrithub.io:29418/eclipse/titan.ProtocolModules.DIAMETER_ProtocolModule_Generator'
I don't intend to "spoof" any author e-mail addresses, but the problem here is that the gerrit repository seems to lag behind the github repository:
* gerrit is at ead78c874cfc10e2836f669e90e989df0c2de3cd (Aguust 13, 2018)
* github is two commits further at ffd939595a08da1b8c8176aaa1f8578bfe02a912 (April 2019)
So when I push to gerrit, git wants to push the two missing commits *and* my commit to gerrit, which fails.
Can somebody please make sure that those repositories are automatically in sync to enable the push of patches to gerrit? Thanks!
Re: problems contributing to DIAMETER_ProtcolModule_Generator / gerrit out of sync? [message #1819303 is a reply to message #1819294] |
Sun, 12 January 2020 16:35   |
Kristof Szabados wrote on Sun, 12 January 2020 11:53Hi Harald,
Now the gerrit repository should be in sych.
Please try to make your commit again.
Thanks, it has worked: https://review.gerrithub.io/c/eclipse/titan.ProtocolModules.DIAMETER_ProtocolModule_Generator/+/481377
We will also see if we can make some automated solution for this ... but that might take some time.
Is there something I can help with? In our installations, we typically use the gerrit server as master and then use the gerrit replication plugin to make it automatically replicate to other sites: https://gerrit.googlesource.com/plugins/replication/+doc/master/src/main/resources/Documentation/config.md
I don't think it can do inbound replication, though. But in the end, it shouldn't require more than a cron job that runs on a git repo with two remotes, and then pulls from one repo and pushes to another., something like:
git clone --mirror git@example.com/upstream-repository.git
cd upstream-repository.git
git push --mirror git@mirror-example.com/new-location.git
The only tricky part is that you'd of course have to have permission to do so, i.e. the user account of the cron job would need a SSH key that's authorized to do the push --mirror to the destination, ideally without passphrase.
FUDForum. Page generated in 0.03777 seconds
