Home » Modeling » Compare » Class loader error - two versions of Guava(was: Troubleshooting Guide for EMF Compare?)
Class loader error - two versions of Guava [message #1819260] Fri, 10 January 2020 10:31 Go to next message
Using the code from https://github.com/nbhusare/EMF-Compare/ as an example and the EMF Compare Developer Guide, I've created a customized DifferenceFilter, DiffBuilder, FeatureFilter and PostProcessor. I've got JUnit5 tests using sample XText based models that pass (Both models stored as strings and models loaded from files).
The next step is to get all of this hooked into the UI. That's where I'm having a problem. I've followed the directions from the Developer's Guide to set up the extnsion points, and I've added the Content Type Association in Eclipse. When I did this initially, it worked - intermittently. Now it doesn't work at all.
The problem I'm getting is a class loader error (see below)
Caused by: java.lang.LinkageError: loader constraint violation: when resolving overridden method "com.honeywell.fractool.NoSemanticDifferenceFilter.getPredicateWhenSelected()Lcom/google/common/base/Predicate;" the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) of the current class, com/honeywell/fractool/NoSemanticDifferenceFilter, and its superclass loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader), have different Class objects for the type com/google/common/base/Predicate used in the signature
I suspect this worked in the past simply because the load order is unstable and occasionally happened to be in an order that was OK.
My questions are:
1) How to I solve this?
2) More generally, is there a troubleshooting guide for this kind of thing that I can refer to?
Other notes: This problem originally started with Eclipse 2019-09 on a Windows 10 machine. I've updated to Eclipse 2019-12. I've got the latest version of EMF Compare available via the Marketplace (3.3.8.201909101346). BTW - note that this is not the version that the EMF Compare site says should be part of the 2019-12 release. Don't know why. The same problem occurs with both versions of Eclipse.
[Updated on: Tue, 14 January 2020 12:03] by Moderator
Re: Troubleshooting Guide for EMF Compare? [message #1819380 is a reply to message #1819260] Tue, 14 January 2020 03:08 Go to previous messageGo to next message
This problem means that you have multiple guava version in your environment, which usually doesn't end well. This likely happens because of the version of EMF Compare you're using, since I've only updated the version of Guava used by EMF Compare in 3.3.9.
The version you're getting through the marketplace is not the correct one because of an oversight on my part : I've forgotten to actually push the released 3.3.9 version so it is not available for download. It should now be available through either the marketplace or directly from https://download.eclipse.org/modeling/emf/compare/updates/releases/3.3/R201911051515
Laurent Goubet
Obeo
Re: Troubleshooting Guide for EMF Compare? [message #1819407 is a reply to message #1819380] Tue, 14 January 2020 11:57 Go to previous messageGo to next message
I updated to 3.3.9. It looks like that fixed the problem. Thanks!
Re: Class loader error - two versions of Guava [message #1864481 is a reply to message #1819260] Tue, 19 March 2024 06:52 Go to previous message
I happen to come across the same error.
Current version: EMF Compare 3.3 (current marketplace installation). Supporting guava are: [27.0.0,30.2.0) but we are already using guava_32.1.2 in our project.
Previous Topic:EMF Compare crashing when merging Sirius models
Next Topic:EMF Compare crashing when instantiating multiple times in a modal
Current Time: Sat Oct 04 18:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.04226 seconds
