Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » IOclHelper and parsing ocl expression of any result type
IOclHelper and parsing ocl expression of any result type [message #18192] Fri, 27 January 2006 12:41 Go to next message
Is there a safe way how to parse a general OCL expression of any result type
(similarly as with *.emf.ocl.query.QueryFactory) ?
IOclHelper only provides methods for creating set of constraint expressions.
The only method applicable in classifier context here is createInvariant and
I would expect that
it requires a Boolean type expression. However, it does not and
createInvariant(String expression)
method is used elsewhere for parsing a generic expression
(for instance:
org.eclipse.emf.ocl.examples.interpreter.console.OclResource .save(...)).
Could there be a stronger contract for clients to create a query like
OclExpression ?
I can not use QueryFactory itself as I need to use specific Environment.
/Radek
Re: IOclHelper and parsing ocl expression of any result type [message #18209 is a reply to message #18192] Fri, 27 January 2006 13:27 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Radek,
Some days ago I've tried the following:
try
String path = "c:/ws/mde/com.sympedia.density.mde/model/mde.deploy";
String expr = "Deployment.allInstances()->select(dependencies->exists(r : Reference | r.target.id = 'system'))";
EObject eObject = EcoreHelper.getXMIObject(path);
EClass eClass = eObject.eClass();
EcoreEnvironmentFactory factory = new EcoreEnvironmentFactory(EPackage.Registry.INSTANCE);
Map extentMap = factory.createExtentMap(eObject);
Environment env = factory.createClassifierContext(eClass);
OclExpression ast = ExpressionsUtil.createInvariant(env, expr, true);
Query query = QueryFactory.eINSTANCE.createQuery(ast);
query.setExtentMap(extentMap);
Object result = query.evaluate(eObject);
System.out.println("Success: " + result);
MessageDialog.openInformation(shell, "Success", result.toString());
catch (Exception ex)
ex.printStackTrace();
MessageDialog.openInformation(shell, "Failure", ex.toString());
If you use ExpressionsUtil, don't forget to add antlr to your prerequisites!
Cheers
/Eike
Radek Dvorak schrieb:
> I would expect that
> (for instance:
> OclExpression ?
> Regards,
> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #18244 is a reply to message #18192] Fri, 27 January 2006 14:35 Go to previous messageGo to next message
Hi, Radek,
I agree that the ambiguity of the "createInvariant" method on the IOclHelper
is confusing. I think to have an additional "createQuery()" operation
would have been a good counterpart to createInvariant(), which could then
have asserted the boolean result type. As it is, adding this precondition
to the existing createInvariant() method would be an API-breaking change
but, hey, this is still version 1.0.0 after all.
How about you raise a bugzilla and we'll see what can best be done about it?
Christian
Radek Dvorak wrote:
> type
> expressions.
> and I would expect that
> (for instance:
> OclExpression ?
> Regards,
> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #18346 is a reply to message #18244] Mon, 30 January 2006 06:06 Go to previous messageGo to next message
Hi Christian,
I have submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=125684
I assume then that I can safely use "createInvariant" for my use-case until
this bug is resolved, right ?
/Radek
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:drdsl9$1rf$1@utils.eclipse.org...
> Hi, Radek,
> IOclHelper
> it?
> Christian
> Radek Dvorak wrote:
>> Hi,
>> type
>> expressions.
>> (for instance:
>> OclExpression ?
>> Regards,
>> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #18379 is a reply to message #18346] Mon, 30 January 2006 08:55 Go to previous message
Yes, that is correct.
Thanks!
Christian
Radek Dvorak wrote:
> Hi Christian,
> until this bug is resolved, right ?
> /Radek
>> Hi, Radek,
>> IOclHelper
>> precondition to the existing createInvariant() method would be an
>> API-breaking change but, hey, this is still version 1.0.0 after all.
>> it?
>> Thanks,
>> Christian
>> Radek Dvorak wrote:
>>> Hi,
>>> type
>>> expressions.
>>> (for instance:
>>> OclExpression ?
>>> Regards,
>>> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #564586 is a reply to message #18192] Fri, 27 January 2006 13:27 Go to previous message
Hi Radek,
try
Cheers
/Eike
> I would expect that
> (for instance:
> OclExpression ?
> Regards,
> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #564647 is a reply to message #18192] Fri, 27 January 2006 14:35 Go to previous message
Hi, Radek,
Christian
Radek Dvorak wrote:
> type
> expressions.
> (for instance:
> OclExpression ?
> Regards,
> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #564810 is a reply to message #18244] Mon, 30 January 2006 06:06 Go to previous message
Hi Christian,
/Radek
> Hi, Radek,
> IOclHelper
> it?
> Christian
> Radek Dvorak wrote:
>> Hi,
>> type
>> expressions.
>> (for instance:
>> OclExpression ?
>> Regards,
>> /Radek
Re: IOclHelper and parsing ocl expression of any result type [message #564899 is a reply to message #18346] Mon, 30 January 2006 08:55 Go to previous message
Thanks!
Christian
Radek Dvorak wrote:
> Hi Christian,
> /Radek
>> Hi, Radek,
>> IOclHelper
>> it?
>> Thanks,
>> Christian
>> Radek Dvorak wrote:
>>> Hi,
>>> type
>>> expressions.
>>> (for instance:
>>> OclExpression ?
>>> Regards,
>>> /Radek
Previous Topic:IOclHelper and parsing ocl expression of any result type
Next Topic:Incorrect OCL error messages on correct OCL
Current Time: Sat Nov 01 21:49:22 EDT 2025
Powered by FUDForum. Page generated in 0.04473 seconds
