Home » Eclipse Projects » Rich Client Platform (RCP) » Debug configuration - HELP
Debug configuration - HELP [message #1819178] Thu, 09 January 2020 09:58 Go to next message
So I am programmatically creating a debug configuration. Everything is good and every attribute is set as I wanted it to be, except for the stopping at main.
I am using this code: configuration.setAttribute(ICDTLaunchConfigurationConstants.ATTR_DEBUGGER_STOP_AT_MAIN, false);
And for some reason, the box is still checked.
Any advice? Thank you!
Re: Debug configuration - HELP [message #1819190 is a reply to message #1819178] Thu, 09 January 2020 11:59 Go to previous messageGo to next message
I think you should be asking this on the Eclipse CDT forum: https://www.eclipse.org/forums/index.php?t=thread&frm_id=80
Re: Debug configuration - HELP [message #1819197 is a reply to message #1819190] Thu, 09 January 2020 14:44 Go to previous messageGo to next message
Set a conditional breakpoint and see where else this key is being used? I found the ordering of calls within the debug classes to be pretty confusing.
Brian.
Re: Debug configuration - HELP [message #1819334 is a reply to message #1819197] Mon, 13 January 2020 07:23 Go to previous messageGo to next message
I did not manage to find any calls. Do you have any other ideas?
Thank you!
Re: Debug configuration - HELP [message #1819369 is a reply to message #1819334] Mon, 13 January 2020 21:37 Go to previous messageGo to next message
Where and when are you setting this value? It's hard to make suggestions without any details!
Re: Debug configuration - HELP [message #1819444 is a reply to message #1819369] Wed, 15 January 2020 08:37 Go to previous messageGo to next message
My plugin has its main objective the creation of a project with some files in it. I have a method that creates the debug configuration when a button is clicked.
Inside the method, I get the Launch manager, the type of launch (which because it is a debug remote application type, I use org.eclipse.cdt.launch.remoteApplicationLaunchType), I create a working copy and after that I just set attributes. Every attribute is set perfectly, except for stopping at main.
Thank you!
Re: Debug configuration - HELP [message #1819448 is a reply to message #1819444] Wed, 15 January 2020 09:54 Go to previous messageGo to next message
I think you need to look at the logic in the CDT UI parts then? Taking a quick looking at the CDT source, CDT launch UIs use other guards to govern the use of the stop-in-main.
https://github.com/eclipse-cdt/cdt/blob/830bf8074c1ff22436c9ae54f2c8401ec3c418a9/dsf-gdb/org.eclipse.cdt.dsf.gdb.ui/src/org/eclipse/cdt/dsf/gdb/internal/ui/launching/CDebuggerTab.java#L355-L373
Re: Debug configuration - HELP [message #1819493 is a reply to message #1819448] Thu, 16 January 2020 04:33 Go to previous messageGo to next message
"You're a wizard, Harry!"
Thank you! Finally managed to solve this bloody problem.
Kind regards!
Re: Debug configuration - HELP [message #1819496 is a reply to message #1819448] Thu, 16 January 2020 04:58 Go to previous messageGo to next message
And since you are a wizard, I will try my luck.
Do you know if there exists a list or a way to find all of Eclipse preferences? I am trying to make the switch from Automatic GDB DSF mode in the debug configuration to manual.
Thank you!
Re: Debug configuration - HELP [message #1819513 is a reply to message #1819496] Thu, 16 January 2020 09:46 Go to previous message
Sadly no. There's no declarative mechanism for defining preferences so code can create preferences at will. You can use tools like Oomph's preference recorder (https://www.eclipse.org/community/eclipse_newsletter/2014/november/article2.php provides a good overview) to at least capture what preferences are being set.
Brian.
Previous Topic:Deployment decisions for an exported RCP Product
Next Topic:Plugins load broken by org.eclipse.ui.decorator
Current Time: Tue Jul 22 04:12:29 EDT 2025
Powered by FUDForum. Page generated in 0.06293 seconds
