Running eclipse.exe (octopus.exe) after maven tycho build does not start-up [message #1818697] |
Mon, 23 December 2019 13:11  |
The following tooling SW versions are used for my product (named octopus):
Java 13
JavaFX 13
Eclipse 2019-09
maven 3.6.3
tycho 1.5.1
I am developing an e(fx)clipse E4 RCP application featuring a test automation framework. I am using the recommended eclipse tycho folder structure and running the product with Eclipse IDE works fine. However, after successful maven-tycho build, running the application (octopus.exe) fails with the following exception:
Exception in Application start method
java.lang.RuntimeException: Exception in Application start method
at javafx.graphics/com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:900)
at javafx.graphics/com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:195)
at java.base/java.lang.Thread.run(Thread.java:830)
Caused by: java.lang.IllegalAccessError: class org.eclipse.fx.ui.workbench.fx.services.InteractiveStartupService (in unnamed module @0x331144b3) cannot access class com.sun.javafx.tk.Toolkit (in module javafx.graphics) because module javafx.graphics does not export com.sun.javafx.tk to unnamed module @0x331144b3
at org.eclipse.fx.ui.workbench.fx.services.InteractiveStartupService.show(InteractiveStartupService.java:61)
at org.octopus.ui.application.OctopusStartupProgressTracker.stateReached(OctopusStartupProgressTracker.java:45)
at org.eclipse.fx.ui.workbench.fx.E4Application.updateStartupState(E4Application.java:447)
at org.eclipse.fx.ui.workbench.fx.E4Application.jfxStart(E4Application.java:226)
at org.eclipse.fx.ui.workbench.fx.DefaultJFXApp.start(DefaultJFXApp.java:60)
at org.eclipse.fx.ui.workbench.fx.E4MainThreadApplication$ExtendedE4Application.start(E4MainThreadApplication.java:101)
at javafx.graphics/com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$9(LauncherImpl.java:846)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runAndWait$12(PlatformImpl.java:455)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:428)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:391)
at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:427)
at javafx.graphics/com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
at javafx.graphics/com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
at javafx.graphics/com.sun.glass.ui.win.WinApplication.lambda$runLoop$3(WinApplication.java:174)
... 1 more
The exception shows that the unnamed bundle (my octopus application bundle) cannot access type 'com.sun.javafx.tk.Tooljit' because
the module javafx.graphics does not export package 'com.sun.javafx.tk' to the unnamed bundle.
How can this restriction be resolved? How can the 'com.sun.javafx.tk' javafx package get exported to my unamed bundle? I tried to fix it
with all kinds of '--add-exports' '--add-reads' and '--add-modules' vmargs in the octopus.ini, however, without success.
It looks like that these arguments are ignored by the native e(fx)clipse launcher.
I use the type Toolkit in order to synchronize my splash screen and turn it into a startup-dialog. By means of the StartupProgressTrackerService
the splash is hidden and replaced by the startup-dialog.
See uploaded files for parent pom.xml, product.xml, target.xml, generated octopus.ini and config.in.
I am looking for a solution for days . I would appriciate it very much when somebody could help.
FUDForum. Page generated in 0.09698 seconds
