Re: Testing setup profiles - Do I need to restart the installer [message #1819247 is a reply to message #1819243] |
Fri, 10 January 2020 08:18   |
> Is this a bug? If I remove it and add it again, why should the new content now used?
Yes and no. Generally all the resources are loaded in parallel long before you get to the project page because there are on the order of 180 resource involved currently. If all you want is a refresh, better there be such an operation; but you only want a refresh on the one resource, not all 180 of them. Removing a project could unload the resource, if this were actually a common operation/need, i.e., if it were common to edit the setups already opened in the installer; that doesn't seem like a common activity to me though.
> Several steps seem behave differently if I run the setup task from the IDE.
When you open the setup, are you using Navigate -> Open Setup -> <your project's stream>? This is the one the IDE is using. If the redirection Ini has kicked in correctly, this will also be the one in the clone and it will be editable. If it is not editable, then something isn't quite right. I will test whether the IDE is properly refreshing after performing the initial tasks such that the remote setup really is properly redirected to the clone immediately after performing. If this is not working for you currently, a restart of the IDE should work. If that doesn't work, then the redirection in the eclipse.ini is likely wrong.
Re: Testing setup profiles - Do I need to restart the installer [message #1819274 is a reply to message #1819250] |
Sat, 11 January 2020 02:13  |
> Works for me too, if I open the editor in the target. If I change the setup file in the original place without opening the editor in the created target IDE, it did not work.
This is like a brain teaser sentence. I have no idea how many copies/versions of the resource are involved, nor which version is actually being used by any of the IDEs.
> Example:
I did already explain that using Navigate -> Open Setup -> <your project's-stream> to open the editor opens the version/copy the IDE is actually using when Performing. So what does that action actually open for IDE B? It's also useful to click the "Show all resources" button; this will show you the URI of each resource, including that of the primary resource that you opened for editing. Moreover, in the Properties view (double click the Resource object), it shows the Resolved URI for that resource. This will tell you which final location is actually being used. In your Example, is that a file: URI? Is it the one you think you are editing? Note that with this approach you can edit in IDE B.
FUDForum. Page generated in 0.09588 seconds
