Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE [message #1818860] |
Mon, 30 December 2019 14:33  |
I have recently installed Eclipse Reports December 2018 version, using OPENJDK 1.8.0.222 runtime. I can generate tabular reports with no problems. However, I am getting an error when trying to create a chart report.
The example is attached. The report uses a flat file data source.
When I run debug, I get the below error:
Dec 30, 2019 11:12:10 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer start
INFO: [Server] client accepted
Dec 30, 2019 11:12:10 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer$1 run
INFO: [Server] enter request dispatching
Dec 30, 2019 11:12:10 AM org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher configEngine
INFO: User class path received:
Dec 30, 2019 11:12:11 AM org.eclipse.birt.report.model.metadata.ExtensionLoader handleError
SEVERE: Message:The class [org.eclipse.birt.chart.reportitem.ChartReportItemFactoryImpl] can not be instantiated. Error code:FAILED_TO_CREATE_INSTANCE
SEVERE: Message:The class [org.eclipse.birt.chart.reportitem.ChartScriptableClassInfo] can not be instantiated. Error code:FAILED_TO_CREATE_INSTANCE
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.engine.extension.internal.ExtensionManager createObject
WARNING: Can not instantiate class org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl with property class.
WARNING: Can not instantiate class org.eclipse.birt.chart.reportitem.ChartReportItemGenerationProxy with property class.
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.engine.extension.internal.ExtensionManager createReportItemExecutor
WARNING: Create Report Item Executor fail, Config not exist class: reportItem
>>>> Compiled Source: unnamed script
row["Hour"].substring(9,18)
>>>> end compilation.
row["Hour"].substring(0,4)+"-"+row["Hour"].substring(4,6)+"-"+row["Hour"].substring(6,8)
>>>> end compilation.
WARNING: Can not instantiate class org.eclipse.birt.chart.reportitem.ChartReportItemPresentationProxy with property class.
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.engine.api.impl.EngineTask handleFatalExceptions
SEVERE: An error happened while running the report. Cause:
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.processExtendedContent(LocalizedContentVisitor.java:1006)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localizeForeign(LocalizedContentVisitor.java:602)
at org.eclipse.birt.report.engine.presentation.LocalizedContentVisitor.localize(LocalizedContentVisitor.java:176)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:37)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.createReport(ReportLauncher.java:620)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.renderReport(ReportLauncher.java:566)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.run(ReportLauncher.java:480)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.main(ReportLauncher.java:124)
at org.eclipse.birt.report.debug.internal.core.ReportDebugger.start(ReportDebugger.java:39)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
at org.eclipse.equinox.launcher.Main.main(Main.java:1474)
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher renderReport
SEVERE: Engine exception
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2379)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:191)
... 19 more
Dec 30, 2019 11:12:12 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer$1 run
WARNING: [Server] client disconnected
FUDForum. Page generated in 0.12895 seconds
