Home » Newcomers » Newcomers » ERROR IN SETUP MAC OS X 10.15.2(I CAN'T INSTALL ECLIPSE 2019-12 ON MAC OS X)
ERROR IN SETUP MAC OS X 10.15.2 [message #1818601] Fri, 20 December 2019 06:59 Go to next message
When I try to install Eclipse 2019-12 on MAC OS X 10.15.2 I obtain next message " The JVM shared library "/Library/Java/JavaVirtualMachines/jdk-13.0.1.jdk/Contents/Home/bin/../lib/server/libjvm.dylib"
does not contain the JNI_CreateJavaVM symbol."
Anybody knows what's going on?.
Thanks.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818619 is a reply to message #1818601] Fri, 20 December 2019 11:24 Go to previous messageGo to next message
Well that's a new one. I only have a virtual box for testing and it's Sierra; I could not find a Catalina ISO image. You could try a packaged download from:
It's likely to fail the same way because the Eclipse Installer is just an Eclipse application. It would be great if you could report back on your success or failure using the packaged download.
In the worst case you could try Java 8 instead...
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818620 is a reply to message #1818619] Fri, 20 December 2019 11:27 Go to previous messageGo to next message
You might also try to Google "the jvm shared library does not contain the jni_createjavavm symbol" and see if any of those related links help.
Please let us know how it works out for you so we know how best to help the next person.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818649 is a reply to message #1818620] Sat, 21 December 2019 15:12 Go to previous messageGo to next message
I have encountered the exact same error on OS 10.14.6.
I've looked at the links, they all say to edit the Info.plist file in the Package Contents of the Installer app. But I can't do this because it is locked - I assume it wasn't locked pre-2018 when all these responses were written.
My exact error:
Even so, their suggestion was to modify Info.plist to point to the correct directory. But this error clearly identifies the correct directory that I want to use, so even if I was allowed to edit the file I'm not sure it would help.
For background, I have 2 older versions of eclipse installed (eclipse oxygen and june 2019), as well as 2 'javas' - 8 and 13. My goal is to update eclipse to the newest version so that it supports java 13.
EDIT: So I managed to unlock the Info.plist by dragging the app out of the dmg onto the desktop, but now post-edit it says the file (Eclipse Installer.app) is damaged and cannot be opened.
[Updated on: Sat, 21 December 2019 16:09] by Moderator
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818651 is a reply to message #1818649] Sat, 21 December 2019 18:35 Go to previous messageGo to next message
I feel as if it could be an Eclipse problem with adjusting to Java 13; I know 13 wasn't even supported until this newest release. I will monitor this thread until hopefully someone replies with a way to resolve this issue.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818654 is a reply to message #1818651] Sun, 22 December 2019 01:17 Go to previous messageGo to next message
To run on the latest MacOS, the downloaded *.dmg now must be not only be signed but also notarized. Perhaps notarization locks it somehow? I imagine though that if you copied it somewhere, it should no longer be locked. Or are you talking about modifying the Info.plist of the Java installation?
But again, the same comment applies as before. Please try to download a package from here:
The "Eclipse IDE for Java Developers" will have support for Java 13 (as will any other package that contains Java). These downloaded *.dmg are also signed and notarized, and I suspect they'll have the same launch problem as the Eclipse Installer (both being Eclipse applications).
But if no one answers that question, we won't be able to help anyone. :-(
As far as I can tell, the IDE has been tested on MacOS, but I'm not sure which version of the OS, and it appears tested only for Java 8:
https://download.eclipse.org/eclipse/downloads/drops4/R-4.14-201912100610/testResults.php
These instructions explain how you can tell Eclipse to use a specific JVM:
https://wiki.eclipse.org/Eclipse.ini
In the installer, this file is called eclipse-inst.ini.
It would be good to understand if this works for Java 8 but not for Java 13.
And note that an IDE running on Java 8 can still support any version of Java up to and including Java 13. The Preferences pages allow you to configure multiple JREs and use any of them...
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818658 is a reply to message #1818654] Sun, 22 December 2019 09:10 Go to previous messageGo to next message
Ok, so I downloaded the 'Eclipse IDE for java developers", as requested, from the packages which doesn't require installation.
Everything works perfectly fine (including support for Java 13), though of course I think some options are missing in this version that are present in the main version?
[Updated on: Sun, 22 December 2019 09:42] by Moderator
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818660 is a reply to message #1818658] Sun, 22 December 2019 09:54 Go to previous messageGo to next message
No, there is no essential difference with this prepackaged version and what you'd install with the installer so no options will be missing.
Not that you care about the following low level details, but I thought to record them here anyway.
I see libjvm.dylib mentioned here:
https://git.eclipse.org/c/equinox/rt.equinox.framework.git/tree/features/org.eclipse.equinox.executable.feature/library/cocoa/eclipseCocoa.c#n82
And here it's tested for the symbol JNI_CreateJavaVM and when it doesn't find it, it produces the message you see:
https://git.eclipse.org/c/equinox/rt.equinox.framework.git/tree/features/org.eclipse.equinox.executable.feature/library/eclipseJNI.c#n337
But this is the same launcher used by the packaged application as the Eclipse installer application, so I don't understand why one would work and the other not. It also doesn't look like the native launcher itself has changed for some years and this is the first I hear about a problem like this...
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818662 is a reply to message #1818658] Sun, 22 December 2019 10:49 Go to previous messageGo to next message
I just tested this package and returned the same error. I think is something related with Java 13, I think the problem is in the file info.plist inside the installation package, concretely the problem is these 2 lines:
<string>-vm</string><string>/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Commands/java</string>
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/1.8.0.jdk/Contents/Home/bin/java</string>
when you have installed Java 13, the folder is jdk-13.0.1.jdk instead 1.8.0.jdk,
so the right path it index.php/fa/37010/0/would be next:
<string>/Library/Java/JavaVirtualMachines/13.0.1.jdk/Contents/Home/bin/java</string>
but this file can not be changed because is blocked , so I suggest to the team in charge of building the package , please build a new package with the right plist file.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818667 is a reply to message #1818662] Sun, 22 December 2019 12:30 Go to previous messageGo to next message
I would expect the package to have the same error given that it uses the same native launcher executable as the installer...
What I see in Info.plist is list this:
	<key>Eclipse</key>
		<array>
			<!-- to use a specific Java version (instead of the platform's default) uncomment one of the following options,
					or add a VM found via $/usr/libexec/java_home -V
			<string>-keyring</string>
      <string>~/.eclipse_keyring</string>
		</array>
I.e., these VM lines are commented out and are just an "example" for how one could explicitly point at a specific JVM. This can also be accomplished in the eclipse.ini (eclipse-inst.ini) instead, I believe. But I don't believe this is the cause of the problem.
The problem really does seem to be that the symbol the native code is looking for in the JNI library (which it appears to correctly find) does not actually exist and because of that, the application cannot be launched.
Likely all this would work properly with Java 8 and likely the native launcher needs to be improved to handle whatever has changed in Java 13...
I'll hunt if a Bugzilla is already opened for this issue and if not I'll open one, pointing at this thread.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818668 is a reply to message #1818667] Sun, 22 December 2019 12:40 Go to previous messageGo to next message
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=558570 to track this issue. At this point I can only suggest installing Java 8 instead or as well....
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818686 is a reply to message #1818668] Mon, 23 December 2019 04:27 Go to previous messageGo to next message
I wanted to express my thanks to both of you for reporting this problem and for helping to further diagnose the problem. Thanks to your help, and the great help from Eclipse Platform team's committers, the problem is now fixed and re-downloading the fixed *.dmg should work properly on the latest Mac OS:
https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2019-12/R/eclipse-inst-mac64.dmg
The mirrors are still catching up, but in a few hours it should be available on all the mirrors for faster download.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818694 is a reply to message #1818686] Mon, 23 December 2019 09:30 Go to previous messageGo to next message
Indeed it does work now, thank you for your help and attention.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1847890 is a reply to message #1818686] Thu, 11 November 2021 09:52 Go to previous messageGo to next message
I have the same error in the package Eclipse Modeling Tools for mac, I'm using the last mac Os 12,0,1 and the java 8, do you know what are happening?
thanks in advance
oscar
I found the error, was the java I need the 11 ver.
[Updated on: Thu, 11 November 2021 11:12] by Moderator
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1847893 is a reply to message #1847890] Thu, 11 November 2021 12:17 Go to previous message
Now I have the problem with Papyrus RCP I do the installation and shows me the same error, now I have installed the Java 11, any idea??
I include the error in the image below
[Updated on: Thu, 11 November 2021 12:18] by Moderator
Previous Topic:Cannot Find Repo At http://download.eclipse.org/technology/m2e/releases
Next Topic:Unable to download 2020-x R "Eclipse IDE for Enterprise Java Developers"
Current Time: Tue Sep 23 09:34:23 EDT 2025
Powered by FUDForum. Page generated in 0.60837 seconds
