Home » Eclipse Projects » OM2M » Problem when running MyMonitor example(the same problem output when I run MyMonitor example and MyManager example)
Problem when running MyMonitor example [message #1818544] Thu, 19 December 2019 04:54 Go to next message
I am running OM2M on Ubuntu 16.04 Using eclipse LUNA. I run MySensor and MyMonitor, but I get the following error when I run MyMonitor:
HTTP POST http://127.0.0.1:8080/~/in-cse/in-name
{"m2m:ae":{"rr":true,"poa":["http://127.0.0.1:1600"],"api":12346,"rn":"mymonitor"}}
HTTP Response 409
Name already present in the parent collection.
HTTP POST http://127.0.0.1:8080/~/mn-cse/mn-name
{"m2m:sub":{"nu":["/in-cse/in-name/mymonitor"],"rn":"monitorsub","nct":2}}
Event Recieved!
"m2m:sgn" : {
"m2m:vrq" : true,
"m2m:sud" : false
org.json.JSONException: JSONObject["nev"] not found.
at org.json.JSONObject.get(JSONObject.java:471)
at org.json.JSONObject.getJSONObject(JSONObject.java:636)
at org.eclipse.om2m.app.MyMonitor$MyHandler.handle(MyMonitor.java:102)
at com.sun.net.httpserver.Filter$Chain.doFilter(Filter.java:79)
at sun.net.httpserver.AuthFilter.doFilter(AuthFilter.java:83)
at com.sun.net.httpserver.Filter$Chain.doFilter(Filter.java:82)
at sun.net.httpserver.ServerImpl$Exchange$LinkHandler.handle(ServerImpl.java:675)
at sun.net.httpserver.ServerImpl$Exchange.run(ServerImpl.java:647)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
and the same error when I run MyManager:
{"m2m:ae":{"rr":true,"poa":["http://127.0.0.1:1500"],"api":12346,"rn":"mymanager"}}
HTTP Response 409
HTTP POST http://127.0.0.1:8080/~/mn-cse/mn-name/mysensor/data
{"m2m:sub":{"nu":["/in-cse/in-name/mymanager"],"rn":"managersub","nct":2}}
Event Recieved!
"m2m:sgn" : {
"m2m:vrq" : true,
"m2m:sud" : false
at org.eclipse.om2m.app.MyManager$MyHandler.handle(MyManager.java:89)
Could you please help me ti fix this error?
Thank you
Re: Problem when running MyMonitor example [message #1827985 is a reply to message #1818544] Thu, 28 May 2020 06:12 Go to previous messageGo to next message
You can try with "m2m:vrq"
Re: Problem when running MyMonitor example [message #1835123 is a reply to message #1827985] Wed, 25 November 2020 02:32 Go to previous message
Actually, when you create a Subscription resource, the oneM2M CSE will send a Verification Request (vrq) to the provided poa. The endpoint should answer back a status code OK if the vrq attribute is set to true.
Previous Topic:containerDefinition attribute must be provided.
Next Topic:getting 503 error Service Unavailable
Current Time: Sun Jul 27 16:33:15 EDT 2025
Powered by FUDForum. Page generated in 0.03405 seconds
