Home » Language IDEs » C / C++ IDE (CDT) » Looking for description of CDT "Project Explorer " icons (icons )
Looking for description of CDT "Project Explorer " icons [message #1818403] Sat, 14 December 2019 09:34 Go to next message
Here is what Mrs Google said after asked
" Eclipse CDT icons"
This is a reference with no relations to icons .
https://www.eclipse.org/documentation/
And this , but it is all about "git"
https://theprogrammersfirst.blogspot.com/2017/
The question :
is there a documentation published BY ECLIPSE describing meaning of "Project Explorer" icons?
(Correct) link would be sufficient.
Re: Looking for description of CDT "Project Explorer " icons [message #1818418 is a reply to message #1818403] Sun, 15 December 2019 02:49 Go to previous messageGo to next message
Did you try the help documentation?
https://help.eclipse.org/2019-09/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Freference%2Fcdt_u_project_explorer_view.htm&cp=11_4_0_2
The root of all help documentation is here
and old links will be resolved to here.
You should learn to use it.
For the most part, the icons are self-explanatory.
They will also change depending on plugins you have installed.
index.php/fa/36979/0/
index.php/fa/36980/0/
Re: Looking for description of CDT "Project Explorer " icons [message #1818422 is a reply to message #1818418] Sun, 15 December 2019 10:29 Go to previous messageGo to next message
SOLVED
Looks as "terminate and relaunch " launch option fixed the issue.
I won't even guess why.
Disregard - it has nothing to do with "warning".
The project does not get updated until it is closed / opened.
It looks as wrong workspace is being "refresh".
Could somebody help me to VERIFY the following?
Even with option -w set ( inhibit all warnings ) I get warnings in "Problems" .
Each warning has an icon - yellow triangle with exclamation (!) symbol inside.
Same symbol is attached to (tree) root symbol of the project.
In lower left corner.
When I edit my code and proceed to "Build Project" and eventually Run TCF the last editing changes I have made DO NOT take.
Not until I "Close project" and "Open project" - then the "warning icon " (?) goes away and my project will run with the latest changes.
As soon as I go back to editing - the "warning icon" comes back.
I did run a test program without "warnings" and have no similar issue with it.
I did installed clean 2019-09 Eclipse and having SAME issue.
I am not asking for solution, just asking if somebody could be nice and verify this so I quit chasing ghosts.
[Updated on: Sun, 15 December 2019 12:43] by Moderator
Re: Looking for description of CDT "Project Explorer " icons [message #1818423 is a reply to message #1818422] Sun, 15 December 2019 12:07 Go to previous message
I don't think I've ever before encountered anyone with your stream of bad luck.
Now you claim a problem sans any particulars and are asking us to
  • verify you are having it?
  • And you don't want a solution?
What??
Also, what does this have to do with your original post?
If nothing, then it should be a new topic.
You'll have better luck getting answers if you are more specific.
For example, showing the error your are getting.
[Updated on: Sun, 15 December 2019 12:13] by Moderator
Previous Topic:How to run automatically compiled .exe in external console (cmd.exe)
Next Topic:EPL v2 question
Current Time: Sun Jul 20 21:04:22 EDT 2025
Powered by FUDForum. Page generated in 0.05498 seconds
