Home » Eclipse Projects » Sirius » Obeo's BPMN Designer
Obeo's BPMN Designer [message #1818265] Wed, 11 December 2019 02:24 Go to next message
Hi, everyone!
I've installed Obeo Designer Community 11.2 and the items
index.php/fa/36948/0/
and
https://s3-eu-west-1.amazonaws.com/obeo-bpmndesigner-releases/4.0.1/repository/
(BPMN-Designer and Sirius Support for Legacy Queries features)
However, after loading the BPMN examples and trying to execute them, a problem occurs:
index.php/fa/36949/0/
Could someone help me figure out what's causing such a problem, please?
I've explored all links in the Obeo Designer's welcome tab. The documentation seems to replicate the available one on Sirius though. Would there be any documentation on how to transform Ecore models into BPMN diagrams or a tutorial on how to build the BPMN samples in the OD's examples folder?
Thank you for your attention.
Clever.
  • Attachment: untitled.png
    (Size: 13.68KB, Downloaded 850 times)
  • Attachment: image.png
    (Size: 29.07KB, Downloaded 619 times)
Re: Obeo's BPMN Designer [message #1818266 is a reply to message #1818265] Wed, 11 December 2019 02:42 Go to previous messageGo to next message
We need more details to help you:
  • What do you mean by "trying to execute them" exactly (what concrete actions did you do to trigger the error)?
  • Please provide the details of the error.
Not sure I understand what you mean. If you want to create BPMN diagrams from your (or the examples) .bpmn models, well that is what the BPMN modeler enables, provided the .bpmn models can correctly be loaded.
If by "transform Ecore models into BPMN " your mean transforming ".ecore" models into ".bpmn" models, I'm not sure it would make much sense (from my limited understanding of BPMN).
Pierre-Charles
Re: Obeo's BPMN Designer [message #1818268 is a reply to message #1818265] Wed, 11 December 2019 03:29 Go to previous messageGo to next message
I have no problem with the procedure described on https://github.com/ObeoNetwork/BPMN-Designer (README.md).
On this process, the recommended ODCE version is 10.1 and not 11.2. And the feature to install is "BPMN-Designer" and "Sirius Support for Legacy Queries":
index.php/fa/36950/0/
With this installation, I can use the examples without problem:
index.php/fa/36951/0/.
I try with ODCE 11.2 and I have no problem too:
index.php/fa/36952/0/
Laurent
Re: Obeo's BPMN Designer [message #1818301 is a reply to message #1818266] Thu, 12 December 2019 02:33 Go to previous messageGo to next message
Thank you for your reply, Pierre!
I've just tried to reproduce the problem unsuccessfully. It occurred when I double-clicked "representations.aird" though. Now "representations.aird" appears to work fine, but doesn't allow me to create a representation (may you see snapshot below).
There's no log report this time then. The problem now is that the diagram doesn't show up...(may you see snapshot below)
My steps this time were: Right click in the model explorer (Sirius perspective) => New => Example... => BPMN/BPMN Samples => ... => Finish => Right click on folder "BPMN_Designer.examples.nobelprize" => Viewpoints selection => Empty...
index.php/fa/36963/0/
I'd like to use BPMN-Designer to translate annotated Ecore models into BPMN diagrams so that I could have a graphical representation of sequences and operations (that would actually be an alternative to UML's activity and sequence diagrams since Ecore only offers class diagrams). Does it make sense? May you have a look at https://www.eclipse.org/forums/index.php/m/1818104/#msg_1818104
Clever.
  • Attachment: Untitled.png
    (Size: 175.79KB, Downloaded 547 times)
Re: Obeo's BPMN Designer [message #1818302 is a reply to message #1818268] Thu, 12 December 2019 02:45 Go to previous messageGo to next message
Thank you for your reply, Laurent!
It seems OK to me, I've done it...
...however, I have doubts when dealing with http://download.eclipse.org/releases/oxygen/ Could you please detail or provide a snapshot as to what needs to be performed? There's a myriad of plug-ins associated to it...
Clever.
Re: Obeo's BPMN Designer [message #1818305 is a reply to message #1818302] Thu, 12 December 2019 03:32 Go to previous messageGo to next message
There is nothing special to do with it. It must be in the available repositories because the 2 mentioned features could have dependencies, that would be found in it.
Re: Obeo's BPMN Designer [message #1818425 is a reply to message #1818305] Sun, 15 December 2019 17:47 Go to previous messageGo to next message
I'd just like to know which items I should install since there are 1250 available ones, could you please advise me of that?
index.php/fa/36981/0/
Although not originally addressed to you, I'd also appreciate very much if you could give me some guidance on:
and
Clever.
    (Size: 40.42KB, Downloaded 523 times)
Re: Obeo's BPMN Designer [message #1818512 is a reply to message #1818425] Wed, 18 December 2019 01:04 Go to previous message
Hi, everyone!
When I tried to load the examples again earlier today, after clicking on "definitions.bpmn" a new error message popped up:
index.php/fa/36992/0/
Does anyone have a clue upon its meaning?
Then I tried to install the whole bunch of plug-ins below
index.php/fa/36993/0/
However, when the installation finished up and I restarted the Obeo Designer, it got stuck to
index.php/fa/36994/0/
and the tool didn't start at all. I tried several times after crashing the application via task manager and the problem persisted.
Any help would be highly appreciated.
Clever.
    (Size: 9.35KB, Downloaded 499 times)
    (Size: 47.98KB, Downloaded 520 times)
    (Size: 56.95KB, Downloaded 546 times)
Previous Topic:Properties fields in Diagram Description
Next Topic:Performing unrelated tasks as part of separate operations - resource creation, set operation
Current Time: Sat Jul 19 22:32:11 EDT 2025
Powered by FUDForum. Page generated in 0.04789 seconds
