Home » Modeling » TMF (Xtext) » MWE2 code generation is different between Eclipse/Maven
MWE2 code generation is different between Eclipse/Maven [message #1818221] Tue, 10 December 2019 07:23 Go to next message
When I run my MWE2 workflow file from Eclipse, the generated code from my DSL contains "import" statements for each required concept of the metamodel.
For example, in my MyDSLSwitch.java class :
import my.dsl.A;
import my.dsl.B;
When I run my MWE2 workflow file from Maven/Tycho (thanks to https://www.eclipse.org/Xtext/documentation/350_continuous_integration.html#tycho-build), the generated code from my DSL contains only one "import" with a wildcard.
import my.dsl.*;
The other problem is I have a concept named "Iterable" in my grammar.
When the code is generated from Eclipse then "Iterable" is always used in its qualified form "my.dsl.Iterable" to avoid ambiguities with "java.lang.Iterable"
  public my.dsl.Iterable createIterable()
    IterableImpl iterable = new IterableImpl();
    return iterable;
When the code is generated from Maven/Tycho, "Iterable" is not used in its qualified form and leads to compiling errors, because there is an ambiguity with "java.lang.Iterable".
  public Iterable createIterable()
    return iterable;
I don't understand why there is a difference in the generated code between Eclipse and Maven/Tycho.
Is there a solution to get the exact same code generation between Eclipse and Maven/Tycho ?
Re: MWE2 code generation is different between Eclipse/Maven [message #1818222 is a reply to message #1818221] Tue, 10 December 2019 07:29 Go to previous messageGo to next message
i assume the difference is the emf version you use.
how do you call workflow from maven. maybe you can tell it to use the newest version of emf there by specifiying the dependencies explicitely
Re: MWE2 code generation is different between Eclipse/Maven [message #1818225 is a reply to message #1818222] Tue, 10 December 2019 08:06 Go to previous messageGo to next message
It's definitely related to the EMF version. The following change added support for the fact that Iterable in visible in java.lang:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=526187
So that would be in version EMF 2.14. Note that EMF 2.20 has recently been published to Maven.
Re: MWE2 code generation is different between Eclipse/Maven [message #1818227 is a reply to message #1818225] Tue, 10 December 2019 08:38 Go to previous messageGo to next message
Thank Christian and Ed for your prompt answers.
To call the workflow from maven, I use this configuration from (https://www.eclipse.org/Xtext/documentation/350_continuous_integration.html) in my pom.xml
<plugin>
  <groupId>org.codehaus.mojo</groupId>
  <artifactId>exec-maven-plugin</artifactId>
  <version>1.4.0</version>
  <executions>
    <execution>
      <id>mwe2Launcher</id>
      <phase>generate-sources</phase>
      <goals>
        <goal>java</goal>
      </goals>
    </execution>
  </executions>
  <configuration>
    <mainClass>org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher</mainClass>
    <arguments>
      <argument>/${project.basedir}/src/my/mavenized/GenerateHeroLanguage.mwe2</argument>
      <argument>-p</argument>
      <argument>rootPath=/${project.basedir}/..</argument>
    </arguments>
    <classpathScope>compile</classpathScope>
    <includePluginDependencies>true</includePluginDependencies>
    <cleanupDaemonThreads>false</cleanupDaemonThreads><!-- see https://bugs.eclipse.org/bugs/show_bug.cgi?id=475098#c3 -->
  </configuration>
  <dependencies>
    <dependency>
      <groupId>org.eclipse.emf</groupId>
      <artifactId>org.eclipse.emf.mwe2.launch</artifactId>
      <version>2.11.0</version>
    </dependency>
    <dependency>
      <groupId>org.eclipse.xtext</groupId>
      <artifactId>org.eclipse.xtext.common.types</artifactId>
      <version>2.19.0</version>
    </dependency>
    <dependency>
      <artifactId>org.eclipse.xtext.xtext.generator</artifactId>
    </dependency>
    <dependency>
      <artifactId>org.eclipse.xtext.xbase</artifactId>
    </dependency>
    <dependency>
      <artifactId>xtext-antlr-generator</artifactId>
      <version>[2.1.1, 3)</version>
    </dependency>
  </dependencies>
</plugin>
My Eclipse environment is 2019-09 with Xtext SDK 2.19.0 and EMF SDK 2.19.0. I use Java 8 in both Eclipse and Maven.
I will try to add explicit dependency to emf in my pom.xml.
Re: MWE2 code generation is different between Eclipse/Maven [message #1818228 is a reply to message #1818227] Tue, 10 December 2019 09:10 Go to previous messageGo to next message
so you will get emf 2.12 which is still the default in xtext
https://github.com/eclipse/xtext/issues/1282
Re: MWE2 code generation is different between Eclipse/Maven [message #1818231 is a reply to message #1818228] Tue, 10 December 2019 09:59 Go to previous messageGo to next message
Christian, Ed,
By just adding those two dependencies into my pom.xml
<dependency>
         <artifactId>org.eclipse.emf.codegen</artifactId>
</dependency>
<dependency>
          <artifactId>org.eclipse.emf.codegen.ecore</artifactId>
 </dependency>
...my build works !
For a reason I don't understand, maven/tycho/exec-maven-plugin seemed to use a different version of EMF (which one ? I don't know) than expected.
Thank you again
Re: MWE2 code generation is different between Eclipse/Maven [message #1818234 is a reply to message #1818231] Tue, 10 December 2019 11:47 Go to previous message
as i said: it uses the 2.12 that the xtext dependencies above in the list pull
Previous Topic:Yacc to Xtext
Next Topic:Xtext / Xtend 2.20 release
Current Time: Mon Jul 21 18:04:08 EDT 2025
Powered by FUDForum. Page generated in 0.03884 seconds
