Home » Eclipse Projects » Rich Client Platform (RCP) » missing constraint: Import package: javax.xml.stream; version(While launching child eclipse on RCP package, found an issue stating missing constraint)
missing constraint: Import package: javax.xml.stream; version [message #1818067] Thu, 05 December 2019 02:37 Go to next message
Tried with and without orbit & equinox plugins installed on the eclipse 2019-09 patch for JDK 12 found in
https://download.eclipse.org/tools/orbit/downloads/drops/R20190827152740/
https://archive.eclipse.org/equinox/drops/R-4.13-201909161045/?d
But eclipse constantly throwing an error stating
Missing Constraint: Import package: javax.xml.steam ;version "0.0.0"
I tried installing stax-api from maven, but it did not resolve the problem too...
I need javax.xml.bind running as it mandatory to run my VXML files on the child eclipse
Re: missing constraint: Import package: javax.xml.stream; version [message #1818347 is a reply to message #1818067] Fri, 13 December 2019 02:47 Go to previous message
I think it is related to Java 10 (and higher), does this help you?
https://stackoverflow.com/questions/51094274/eclipse-cant-find-xml-related-classes-after-switching-build-path-to-jdk-10/53824670#53824670
Previous Topic:Get the current launch configuration
Next Topic:Non-default Perspective Content no Showing
Current Time: Sun Jul 20 20:35:14 EDT 2025
Powered by FUDForum. Page generated in 0.19402 seconds
