Home » Language IDEs » Java Development Tools (JDT) » 2019-09(test ng)
2019-09 [message #1818047] Wed, 04 December 2019 13:09 Go to next message
This Eclispe version cannot install test ng from the Market Place.
There is an alternative where you can install it from beust.com but that also is not up. Nor is testng.org. Someone did find another way to install:
https://www.techbeamers.com/install-testng-in-eclipse-ide/#method3 (method 3).
But I was wondering, why don't they just package testng in the Eclipse Installation? Shouldn't it be failry easy?
Re: 2019-09 [message #1818049 is a reply to message #1818047] Wed, 04 December 2019 13:35 Go to previous message
The charm of modular software is, that users can choose the components they want, rather than pushing gigabytes at each and every user (perhaps with bloated UI as the result).
If servers where this component can be found are not up, this indicates a problem of upstream maintenance. Adding a dependency with unstable availability to Eclipse doesn't sound like a smooth ride, so better to stay independent.
BTW, I found a Troubleshooting doc for you: https://github.com/cbeust/testng-eclipse/blob/master/docs/Troubleshooting.md
Previous Topic:Breakpoints in Eclipse 4.14M3
Next Topic:Annoying graphic bug on Ubuntu
Current Time: Mon Jul 21 12:13:09 EDT 2025
Powered by FUDForum. Page generated in 0.03196 seconds
