Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Install mqtt paho in windows
Install mqtt paho in windows [message #1817995] Wed, 04 December 2019 00:45 Go to next message
I'm trying to install MQTT Paho on Windows. I got instructions from https://www.eclipse.org/4diac/documentation/html/communication/mqttPaho.html
I get an error when running the "make" command in cmd. The picture below is a description of the error. Is there any solution for this?
Thank you
index.php/fa/36906/0/
  • Attachment: errormqtt.PNG
    (Size: 126.56KB, Downloaded 341 times)
[Updated on: Wed, 04 December 2019 00:46] by Moderator
Re: Install mqtt paho in windows [message #1818008 is a reply to message #1817995] Wed, 04 December 2019 02:39 Go to previous message
The error refers to the compilation of paho. Check the issues in their forum maybe for better support. Last time I tried it was working with version 1.3.0. I used static libraries, because I remember there was a problem with dynamic libraries in windows
Previous Topic:Calculate Time difference in 4diac
Next Topic:Profinet support
Current Time: Tue Nov 04 22:51:30 EST 2025
Powered by FUDForum. Page generated in 0.02913 seconds
