OCLinEcore: Custom validation messages not working [message #1700726] |
Mon, 06 July 2015 12:48  |
Hi all,
I am currently trying to realize custom OCL validation messages by means of the 'OCLinEcoreTutorial' but so far have not been successful. I have performed the following steps:
- Set the following OCL preferences
- Executor targeted by the default OCL delegate: ".../Pivot"
- Realisation of OCL embedded within Ecore models: "Generate Java Code in *Impl classes"
- Create the OCLinEcoreTutorial example
- Open the 'Tutorial.ecore' with the OCLinEcore editor
- Change the 'SufficientCopies' invariant of the 'Books' class as described here
- Generate the model code by means of the genmodel
- Make the generated 'TutorialValidator' extend the 'OCLinEcoreEObjectValidator'
- Run the generated model code
- Create a new model and validate it (with the 'Sample Reflective Ecore Model Editor')
When I validate the model, I always get the default error message (The 'SufficientCopies' constraint is violated ...) instead of the custom error message.
Did I miss anything or does this seem to be a bug? I tried to debug this myself and found that the correct error message seems to be assembled inside the 'SufficientCopies(...)' method of class 'BookImpl'. It is stored in a variable called 'TupleValue'. However, this does not seem to be passed to 'CGStringLogDiagnosticOperation.INSTANCE.evaluate(...)':
final /*@NonNull*/ /*@Thrown*/ TupleValue symbol_0 = ValueUtil.createTupleOfEach(TutorialTables.TUPLid_, sum_4, le_0);
final /*@NonInvalid*/ boolean status = (Boolean)symbol_0.getValue(1/*status*/);
final /*@NonInvalid*/ boolean logDiagnostic = ClassUtil.nonNullState(CGStringLogDiagnosticOperation.INSTANCE.evaluate(evaluator, TypeId.BOOLEAN, TutorialTables.STR_Book_c_c_SufficientCopies, this, diagnostics, context, severity_0, status, TutorialTables.INT_0).booleanValue());
Thanks in advance for any help!
Kind regards
Matthias
Re: OCLinEcore: Custom validation messages not working [message #1700730 is a reply to message #1700726] |
Mon, 06 July 2015 13:06   |
HI
Oops.
CGStringLogDiagnosticOperation was a late addition to support
configurable severities for safe navigation. I can easily understand how
it breaks the code as you have described. However I'm surprised that no
JUnit test detected the breakage. I'm also puzzled that I missed the
regression while reviewing all the tutorials for Mars.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=471948 raised.
Ed Willink
On 06/07/2015 17:48, Matthias Freund wrote:
> Hi all,
> in *Impl classes" Create the OCLinEcoreTutorial example
> described
> http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.ocl.doc%2Fhelp%2FIntegration.html
> Model Editor')
> error message.
> Kind regards
> Matthias
FUDForum. Page generated in 0.05910 seconds
