how to configure access rules for ecj when run by maven? [message #1817883] |
Mon, 02 December 2019 03:53  |
For our project we have set the ecj as the compiler to be used by maven.
I'm searching now how to add access rules to eclipse compiler. For example, i want to forbid usage of the old log4j in our code. What i've found so far is that access rules are passed to the eclipse batch compiler via the classpath option [-org/apache/log4j/**]. But when i add this as option in the compiler argument for the maven plugin, it seems to be ignored.
Here is how is setup the ecj in our pom.xml
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<version>3.8.0</version>
<executions>
<execution>
<id>default-compile</id>
<phase>compile</phase>
<goals>
<goal>compile</goal>
</goals>
<configuration>
<skipMain>true</skipMain>
</configuration>
</execution>
<execution>
<id>compile</id>
<goals>
</goals>
<configuration>
<compilerId>eclipse</compilerId>
<source>1.8</source>
<target>1.8</target>
<compilerArgs>
<arg>-properties</arg>
<arg>${project.basedir}/eclipse.prefs</arg>
<arg>-cp</arg>
<arg>[-org/apache/log4j/**]</arg>
</compilerArgs>
<showWarnings>true</showWarnings>
<showDeprecation>true</showDeprecation>
</configuration>
</execution>
</executions>
<dependencies>
<dependency>
<groupId>org.codehaus.plexus</groupId>
<artifactId>plexus-compiler-eclipse</artifactId>
<version>2.8.5</version>
</dependency>
<dependency>
<groupId>org.eclipse.jdt</groupId>
<artifactId>ecj</artifactId>
<version>3.19.0</version>
</dependency>
</dependencies>
</plugin>
Re: how to configure access rules for ecj when run by maven? [message #1818206 is a reply to message #1818167] |
Tue, 10 December 2019 03:58   |
Thanks, but i don't think this will do the job. The parameter -annotationpath is for providing the location to external annotations, i don't think it is the same as configuring the access rules. In the batch compiler help the access rules are described as
Quote:-cp
-classpath <dir 1>;<dir 2>;...;<dir P> This is a list of directories or jar files used to compile the source files. The default value is the value of the property "java.class.path". Entries are separated by the platform path separator.
Each directory or file can specify access rules for types between '[' and ']' (e.g. [-X] to forbid access to type X, [~X] to discourage access to type X, [+p/X:-p/*] to forbid access to all types in package p but allow access to p/X).
But since in my case the classpath is owned by Maven, i was wondering if is there any other way to provide access rules to ecj. For example, thru the prefs file or the environment or something else, that i'm missing.
Ed Willink wrote on Mon, 09 December 2019 09:22Hi
Not sure if this helps, but in my pom.xml I have:
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>tycho-compiler-plugin</artifactId>
<version>${tycho-version}</version>
<configuration><!-- Workaround Bug 526011 -->
<compilerArgs>
<arg>-annotationpath</arg>
<arg>${project.basedir}/../../plugins/org.eclipse.ocl.pivot/annotations</arg>
</compilerArgs>
</configuration>
Ed Willink
Re: how to configure access rules for ecj when run by maven? [message #1818420 is a reply to message #1818206] |
Sun, 15 December 2019 07:36  |
I had to check the sources for a definite answer, but unfortunately, definition of access rules is so tightly coupled to the classpath, that ecj has no provision to merge this information from two separate sources.
From here you could go in several directions, e.g.:
- Request that m2e adds the access rules to the classpath it builds (based on which information)?
- Request that JDT adds an option for merging classpath & rules (how should classpath entries be matched?)
Both request can be made as enhancement requests in bugzilla, but since I don't see a huge community joining this request, you will likely be asked to contribute the implementation yourself.
Stephan
FUDForum. Page generated in 0.06028 seconds
