Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EEF](IEEFLifecycleManagerProvider contribution)
[EEF] [message #1817881] Mon, 02 December 2019 02:47 Go to next message
I'm working with Sirius and managed to create some custom widgets using the org.eclipse.eef.ide.ui.eefLifecycleManagerProvider extension point.
In the documentation it said that I can also modify an existing widget with this extension point. I'm not finding how to do that.
Re: [EEF] [message #1817884 is a reply to message #1817881] Mon, 02 December 2019 04:09 Go to previous messageGo to next message
I found how to do it in this post : https://www.eclipse.org/forums/index.php?t=msg&th=1083528&goto=1751207&
Unfortunately, I wanted to change how the label of the widget are positioned. I wanted to put them in a group but like they said on this post it's preferable to create custom widgets. The implementation of radio buttons is difficult to reuse for a custom widgets.
[Updated on: Mon, 02 December 2019 04:11] by Moderator
Re: [EEF] [message #1818077 is a reply to message #1817884] Thu, 05 December 2019 05:02 Go to previous message
You won't be able to change how the label of the widget are positioned, you would indeed need a custom widget.
Stephane
Previous Topic:Edapt migrate the class with slots in inverse order
Next Topic:Can EMF Forms change an Ecore model?
Current Time: Sun Jul 20 20:55:01 EDT 2025
Powered by FUDForum. Page generated in 0.26945 seconds
