Home » Modeling » TMF (Xtext) » How to use multi line in XBlockExpression of a dsl
How to use multi line in XBlockExpression of a dsl [message #1817729] Thu, 28 November 2019 04:47 Go to next message
I have a small dsl to store sql statements with variables. Currently I can define this statments in one line. Are there possibility to use the xtend multi line in XblockExpression?
My dsl looks like
Model returns Model:
	{Model}
	'package' package=QualifiedName
	'class' name=ID '{'
		(queries+=Query ( queries+=Query)* )?
Query returns Query:
	{Query}
	'Query' name=EString '(' (parameters+=JvmFormalParameter ( "," parameters+=JvmFormalParameter)* )? ')'
		statement=XBlockExpression
EString returns ecore::EString:
	STRING | ID;
For complex statments it is better to separate it by line breaks, but here it is ok
package hello.world
class QueryManager{
	Query HelloWorld(String param1){
		val sql = "SELECT * from Table where name = "
		sql
How can I defined the XBlockExpression to use that
Query HelloWorld(String param1, String param2){
		val sql = '''SELECT * from Table
                where name = param1 and forename = param2
                order by name asc
		sql
dimg
P.S. I tried to use the
terminal STATEMENT: "'''" -> "''''";
But how can I Escape the character ' ?
Further how can I get this result as String with linebreaks in my ModelInferer?
Maybe it is better to reuse that one from Xtend Grammar
[Updated on: Thu, 28 November 2019 04:55] by Moderator
Re: How to use multi line in XBlockExpression of a dsl [message #1817731 is a reply to message #1817729] Thu, 28 November 2019 05:05 Go to previous messageGo to next message
you have to care about that yourself. (e.g. have a look what xtend does which uses jflex for lexing
p.s. do you know that "" and '' are already Multiline?
Re: How to use multi line in XBlockExpression of a dsl [message #1817734 is a reply to message #1817731] Thu, 28 November 2019 05:26 Go to previous messageGo to next message
Okay thanks for feedback, maybe I use this terminal STATEMENT: '```' -> '```';
And cleaned up the result in the ModelInferrer. Because the result of this description
class QueryManager{
	Query HelloWorld(String param1)```
	SELECT * from Table where name = <param1>
returns the JavaCode with
@SuppressWarnings("all")
public class QueryManager {
  public static String HelloWorld(final String param1) {
    return ```
Re: How to use multi line in XBlockExpression of a dsl [message #1817739 is a reply to message #1817734] Thu, 28 November 2019 06:03 Go to previous messageGo to next message
you need to implement a value converter for your terminals
Re: How to use multi line in XBlockExpression of a dsl [message #1817740 is a reply to message #1817739] Thu, 28 November 2019 06:30 Go to previous message
Thank you very much this is what I need.
Previous Topic:Unable to run unit tests
Next Topic:Testing code generation
Current Time: Sun Jul 20 21:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.26176 seconds
