Home » Eclipse Projects » Eclipse Scout » Get data for form from database
Get data for form from database [message #1817346] Wed, 20 November 2019 12:34 Go to next message
I'am currently trying to display some user data. For this I set up a UserTablePage, a UserNodePage and a UserForm.
The UserTablePage obviously shows all users in a table. For every user a child page of type UserNodePage is created. The node pages only content is the UserForm, which should display more details than the table.
Everything works fine, except the UserForm. The load() in the UserService looks like this:
public UserFormData load(UserFormData formData) {
    String sql = ""
            + "SELECT name "
            + "FROM user_account "
            + "WHERE token = ??? "
            + "INTO :name";
    SQL.selectInto(sql, formData);
    return formData;
This does not work, since I don't know how to get information about the user I'm trying to get data for (the ??? in the query).
I figured I can give the UserNodePage the needed information with this setter/getter:
@FormData
public String getToken() {
    return token;
@FormData
public void setToken(String token) {
    this.token = token;
But how can I pass this information to the UserForm?
Some additional information:
To immediatly view the UserForm, I added a ViewHandler:
public class ViewHandler extends AbstractFormHandler {
    protected void execLoad() {
        IUserService service = BEANS.get(IUserService.class);
        UserFormData formData = new UserFormData();
        exportFormData(formData);
        formData = service.load(formData);
        importFormData(formData);
        setEnabledPermission(new UpdateUserPermission());
The handler gets called in the UserForms constructor:
public UserForm() {
    setHandler(new ViewHandler());
Best regards and thanks for your help in advance
yannek
Re: Get data for form from database [message #1817368 is a reply to message #1817346] Thu, 21 November 2019 04:32 Go to previous messageGo to next message
The Scout backend knows the authenticated user. You could for instance call ServerSession.get().getUserId() in your backend to get the user-ID. The user-ID is set by the AccessControlService#getUserIdOfCurrentSubject. From there it's regular SQL logic: you can lookup the user in the USER_ACCOUNT by its ID. I don't know your data-model: maybe the "token" _is_ the ID? or you need to join over a TOKEN table to find which user-ID belongs to that token? Anyway, you don't need to pass the user from the client to the backend.
Re: Get data for form from database [message #1817378 is a reply to message #1817368] Thu, 21 November 2019 07:33 Go to previous messageGo to next message
Thanks for the answer.
Unfortunately I don' need to know which user is currently working/clicking. I need to see details about every user, not only mine.
https://i.imgur.com/CTTDxND.jpg
As you can see on the image, the UserNodePages are there as the UserTablePages children, but the field "Name" on the UserForm is empty because I don't know how to access the token (which is also the primary key of the user table in the database).
Re: Get data for form from database [message #1817390 is a reply to message #1817378] Thu, 21 November 2019 09:15 Go to previous messageGo to next message
I see. Well that's exactly what is explained in the Scout Beginners Guide, Chapter 4.6. Adding a Form to Create/Edit Persons. . You should Take a look at the Contacts application, which does the same thing. The source-code is hosted here, check out the PersonForm. As you can see, the personId is passed to that Form and annotated with @FormData. In the execLoad() method a FormData with that personId is passed to the server, where you can access the personId again and use it in a SQL statement.
Re: Get data for form from database [message #1850109 is a reply to message #1817390] Wed, 16 February 2022 04:12 Go to previous messageGo to next message
Does UserTablePage show all user processes? Are you displaying users of different computers or users of the same computer?
Re: Get data for form from database [message #1851200 is a reply to message #1817346] Wed, 30 March 2022 08:41 Go to previous message
Try to see the content of your UserTablePage, UserNodePage, and for your UserForm. Look if there are any mistakes that you oversaw. What are the errors on display? I have a different way of categorizing the data. Last time SALVAGEDATA restored it after a stupid mistake. Don't exhaust the program with too many commands, especially if they are not clear, they can put the whole information in danger. I like the advice Andre gave you. Go to the section "adding form fields", and from there follow every step in detail. Send us some pics if nothing changes.
[Updated on: Fri, 01 April 2022 18:54] by Moderator
Previous Topic:AbstractSmartField - parsing for an exact value
Next Topic:AbstractDateTimeField with Milliseconds
Current Time: Mon Jul 21 06:12:23 EDT 2025
Powered by FUDForum. Page generated in 0.30114 seconds
