Home » Language IDEs » C / C++ IDE (CDT) » Unable to use custom linker script in Eclipse Mars?
Unable to use custom linker script in Eclipse Mars? [message #1817362] Thu, 21 November 2019 00:53 Go to next message
Hi guys,
So after a long time scouring the internet, I've gotten to the stage where I'm able to use a cross-compiler in Eclipse Mars.
Problem is, I cannot figure out how to use a custom linker script.
This is what I've done:
1) File>New>C++ Project
2) Named my project
3) Chose "Empty Project" in "Project Type"
4) Chose "Cross GCC" in "Toolchain"
5) Highlighted the project in "Project Explorer", right clicked and chose "Properties"
6) C/C++ Build>Settings
7) In "Cross Settings" I put "i686-elf-" in Prefix and in Path I put the path to the cross-compiler
Doing just the above has allowed me to use the cross-compiler. But the problem now is that when I go to "General" under "Cross G++ Linker" The only options I have are:
Do not use standard start files (-nostartfiles)
Do not use default libraries(-nodefaultlibs)
No startup or default libs (-nostdlib)
Omit all symbol information (-s)
I don't have the option to explicitly tell eclipse to use a certain link.ld file of my choosing.
Any ideas?
Re: Unable to use custom linker script in Eclipse Mars? [message #1817423 is a reply to message #1817362] Thu, 21 November 2019 16:31 Go to previous message
You can add -T link.ld to any of the following:
  • Miscellaneous Linker Flags
  • The linker Command
  • The Command Line Pattern
  • As two consecutive -Xlinker parms (-T, link.ld)
Previous Topic:Right-click in project explorer generates errors
Next Topic:How to add an external library to eclipse cmake projects
Current Time: Fri Nov 07 20:55:37 EST 2025
Powered by FUDForum. Page generated in 0.03308 seconds
