Home » Language IDEs » Java Development Tools (JDT) » Cannot resolve binding of Custom ParameterizedType's attributes
Cannot resolve binding of Custom ParameterizedType's attributes [message #1817163] Sun, 17 November 2019 00:02 Go to next message
I have a custom class say, CustomVisitor which extends the ASTVisitor. And, for the following two examples, in the visit(QualifiedName node) method, I am trying to get the binding of the qualified names to get to their declarations and assigning them the new values. However, for the local ParameterizedType, Fist, if I dclare them with type arguments (like in Code 1), the binding of fist.item and fist.size become null. And, for the code 2 where fist is declared without a type argument, the binding of fist.item and fist.size is found correctly in the above mentioned visit method.
I should mention that I have compiled and ran both examples with Java 1.8 and both ran successfully and showed the same console output with just a warning.
But I can't figure out why resolveBinding for the QualifiedNames are returning null when the type argument is given for the parameterized types. And, it is only happening to the local objects, not to the fields. For example, the binding of pair.fst and pair.snd are resolving properly with the type arguments.
Any help would be appreciated.
Code 1:
class Pair<T, U>
    public T fst;
    public U snd;
    public Pair(T fst, U snd)
        this.fst = fst;
        this.snd = snd;
    public Pair()
class Fist<T> {
    public T item;
    public Integer size;
    public Fist() {
class Foo {
    int a;
    String aa;
public class Test
    static Pair<Foo, Fist<String>> pair = new Pair();
    public static void main(String[] args)
        String a = "haha";
        Integer b = 10;
        Foo foo = new Foo();
        foo.a = b;
        foo.aa = a;
        pair.fst = foo;
        Fist<String> fist = new Fist<String>();
        fist.item = a;
        fist.size = b;
        pair.snd = fist;
        System.out.println("item: "+pair.snd.item);
Code 2:
class Pair<T, U>
    public T fst;
    public U snd;
        this.fst = fst;
        this.snd = snd;
    public Pair()
class Fist<T> {
    public T item;
    public Fist() {
class Foo {
    int a;
    String aa;
public class Test
        String a = "haha";
        Integer b = 10;
        foo.a = b;
        foo.aa = a;
        pair.fst = foo;
        Fist fist = new Fist();
        fist.item = a;
        fist.size = b;
        pair.snd = fist;
Re: Cannot resolve binding of Custom ParameterizedType's attributes [message #1817179 is a reply to message #1817163] Sun, 17 November 2019 23:53 Go to previous messageGo to next message
Can you please provide the program which you used to get the nodes and the bindings?
Re: Cannot resolve binding of Custom ParameterizedType's attributes [message #1817239 is a reply to message #1817179] Mon, 18 November 2019 23:36 Go to previous messageGo to next message
The program is like this...
public class CustomVisitor extends ASTVisitor {
         public boolean visit(QualifiedName node){
                    IBinding binding = node.resolveBinding();
                    if(binding instanceof IVariableBinding){
                                // do something
The problem is occurring in node.resolveBinding(). It is returning null for the above test cases I mentioned above.
Re: Cannot resolve binding of Custom ParameterizedType's attributes [message #1817492 is a reply to message #1817239] Sat, 23 November 2019 13:44 Go to previous message
I don't have an answer, but I'd like to suggest using JDT's ASTView feature to investigate how exactly the given source code is represented by AST and bindings.
Previous Topic:Cannot generate entities from existing MySQL db using JPA Tools
Next Topic:[Solved] Message "Error creating Groovy: java.lang.ClassNotFoundException" when using JDT'
Current Time: Thu Sep 18 03:39:14 EDT 2025
Powered by FUDForum. Page generated in 0.06069 seconds
