Home » Eclipse Projects » Paho » publish problem MQTT(having problems with publish)
publish problem MQTT [message #1817158] Sat, 16 November 2019 16:33
I have a class Mqtt
and a class with layout called Hoofdmenu (code below).
Here i want to send a message into the mqtt
=> MqttCommunicatie.publishToTopic(MqttCommunicatie.m qttAndroidClient,"esp/test","Message MQTT");
when i publishToTopic after the subscribe into class Mqtt the i receive the message
when i do the same into the class Hoofdmenu it doens't work
what do i do wrong ? Or what can i do so it will work ?
now receive the message "MyHome is stopped Open app again"
code MQTT class
package com.example.myhome;
import org.eclipse.paho.android.service.MqttAndroidClient;
import org.eclipse.paho.client.mqttv3.IMqttActionListener;
import org.eclipse.paho.client.mqttv3.IMqttDeliveryToken;
import org.eclipse.paho.client.mqttv3.IMqttToken;
import org.eclipse.paho.client.mqttv3.MqttCallback;
import org.eclipse.paho.client.mqttv3.MqttClient;
import org.eclipse.paho.client.mqttv3.MqttConnectOptions;
import org.eclipse.paho.client.mqttv3.MqttException;
import org.eclipse.paho.client.mqttv3.MqttMessage;
import org.eclipse.paho.client.mqttv3.MqttPersistenceException;
import android.content.Context;
import android.content.DialogInterface;
import android.util.Log;
import androidx.appcompat.app.AlertDialog;
import java.io.UnsupportedEncodingException;
public class Mqtt {
    public MqttAndroidClient mqttAndroidClient;
    final String serverUri = "tcp://***";
    final String clientId = "***";
    final String username = "***";
    final String password = "***";
    public Mqtt(Context context) {
        mqttAndroidClient = new MqttAndroidClient(context, serverUri, clientId);
        mqttAndroidClient.setCallback(new  MqttCallback() {
            //@Override
            public void connectComplete(boolean b, String s) {
                Log.w("mqtt", s);
            public void connectionLost(Throwable throwable) {
            public void messageArrived(String topic, MqttMessage mqttMessage) throws Exception {
                Log.w("Mqtt", mqttMessage.toString());
            public void deliveryComplete(IMqttDeliveryToken iMqttDeliveryToken) {
        connect();
    public void setCallback(MqttCallback callback) {
        mqttAndroidClient.setCallback(callback);
    private void connect() {
        MqttConnectOptions mqttConnectOptions = new MqttConnectOptions();
        //mqttConnectOptions.setAutomaticReconnect(true);
        mqttConnectOptions.setCleanSession(false);
        mqttConnectOptions.setUserName(username);
        mqttConnectOptions.setPassword(password.toCharArray());
        try {
            mqttAndroidClient.connect(mqttConnectOptions, null, new IMqttActionListener() {
                public void onSuccess(IMqttToken asyncActionToken) {
                   //DisconnectedBufferOptions disconnectedBufferOptions = new DisconnectedBufferOptions();
                   // disconnectedBufferOptions.setBufferEnabled(true);
                   // disconnectedBufferOptions.setBufferSize(100);
                    //disconnectedBufferOptions.setPersistBuffer(false);
                    //disconnectedBufferOptions.setDeleteOldestMessages(false);
                   // mqttAndroidClient.setBufferOpts(disconnectedBufferOptions);
                    subscribeToTopic("esp/test");
                    //publishToTopic("esp/test","POPdd");
                public void onFailure(IMqttToken asyncActionToken, Throwable exception) {
                    Log.w("Mqtt", "Failed to connect to: " + serverUri + exception.toString());
        } catch (MqttException ex) {
            ex.printStackTrace();
    private void subscribeToTopic(String Topic) {
        try {
            mqttAndroidClient.subscribe(Topic, 0, null, new IMqttActionListener() {
                    Log.w("Mqtt", "Subscribed!");
                    Log.w("Mqtt", "Subscribed fail!");
            System.err.println("Exceptionst subscribed");
    public void publishToTopic(MqttAndroidClient client,String Topic,String MessageForTopic) {
        String payload = MessageForTopic ;
        byte[] encodedPayload = new byte[0];
        try {
            encodedPayload = payload.getBytes("UTF-8");
            MqttMessage message = new MqttMessage(encodedPayload);
            client.publish(Topic, message,null,new IMqttActionListener() {
               // @Override
                    Log.w("Mqtt", "Published!");
                    Log.w("Mqtt", "Published fail!");
        } catch (UnsupportedEncodingException e) {
            e.printStackTrace();
        } catch (MqttPersistenceException e) {
        } catch (MqttException e) {
code Hoofdmenu
import androidx.appcompat.app.AppCompatActivity;
import androidx.viewpager.widget.ViewPager;
import android.os.Bundle;
import android.view.View;
import android.widget.TextView;
import com.example.myhome.HoofdmenuTabs.PagerAdapter;
import com.google.android.material.tabs.TabLayout;
public class Hoofdmenu extends AppCompatActivity {
    public Mqtt MqttCommunicatie;
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_hoofdmenu);
        TabLayout tabMenu = (TabLayout) findViewById(R.id.tabMenu);
        final ViewPager viewPager = (ViewPager) findViewById(R.id.tabpager);
        final PagerAdapter adapter = new PagerAdapter
                (getSupportFragmentManager(), tabMenu.getTabCount());
        viewPager.setAdapter(adapter);
        viewPager.addOnPageChangeListener(new TabLayout.TabLayoutOnPageChangeListener(tabMenu));
        tabMenu.setOnTabSelectedListener(new TabLayout.OnTabSelectedListener() {
            public void onTabSelected(TabLayout.Tab tab) {
                viewPager.setCurrentItem(tab.getPosition());
            public void onTabUnselected(TabLayout.Tab tab) {
            public void onTabReselected(TabLayout.Tab tab) {
        startMqtt();
        MqttCommunicatie.publishToTopic(MqttCommunicatie.mqttAndroidClient,"esp/test","Message MQTT");
    private void startMqtt(){
        MqttCommunicatie = new Mqtt(getApplicationContext());
        MqttCommunicatie.setCallback(new MqttCallback() {
            //@Override
                Log.w("Debug", mqttMessage.toString());
                //dataReceived.setText(mqttMessage.toString());
Previous Topic:Encryption/Decryption
Next Topic:Getting Started
Current Time: Sun Jul 20 22:50:00 EDT 2025
Powered by FUDForum. Page generated in 0.04221 seconds
