Home » Newcomers » Newcomers » Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the JDK(Eclipse installer could not install)
Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the JDK [message #1816623] Fri, 01 November 2019 13:11 Go to next message
I've tried to install eclipse, but it's connected to the web page displaying the following error and it's experiencing a problem with installation
Unfortunately the Java version needed to run Eclipse Installer couldn't be found on your system. You need the following version or a higher version: Java 1.8.0 (64 Bit)
But my JDK version is Aleady 1.8.0_231(64Bit) and i completed setting up the environment variable. (JAVA_HOME, and Path as System Variable)
Normally, using a different IDE like InteliJ(and it works normally on my computer) but it's not possible because I have to submit it as a university assignment using eclipse.
What should I do?
Included File is my CMD screenshot of checking JDK version
  • Attachment: XHYYe.png
    (Size: 19.20KB, Downloaded 326 times)
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816636 is a reply to message #1816623] Sat, 02 November 2019 02:24 Go to previous messageGo to next message
To try to reproduce this problem I installed jdk1.8.0_231 on my machine and ran this from the cmd command line:
.\eclipse-inst.exe -vm "C:\Program Files\Java\jdk1.8.0_231\bin"
But that works fine. Does that work for you?
Also if I put in on my PATH
C:\develop\installer-test>java -version
java -version
java version "1.8.0_231"
Java(TM) SE Runtime Environment (build 1.8.0_231-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.231-b11, mixed mode)
C:\develop\installer-test>.\eclipse-inst
.\eclipse-inst
That works fine as well.
In my <home>/.eclipse/org.eclipse.oomph.jreinfo/infos.txt I have a great many JRE/JDKS that I have tested:
C:\Program Files\Java\jdk-12.0.1;12;0;1;64;true;1561563120591
C:\Program Files\Java\jdk1.8.0_121;1;8;0;64;true;1490692583438
C:\Program Files\Java\jdk1.8.0_112;1;8;0;64;true;1483438804301
C:\Program Files\Java\jdk1.8.0_72\jre;1;8;0;64;false;1453726714255
C:\Program Files\Java\jdk1.8.0_72;1;8;0;64;true;1453726714145
D:\eclipse\JDK-1.9.0-118;9;0;0;64;true;1463017587000
D:\eclipse\JDK-1.7.79\jre;1;7;0;64;false;1428698970000
C:\Program Files\Java\jdk-11.0.1;11;0;1;64;true;1538829134000
C:\Program Files\Java\jdk-12;12;0;0;64;true;1554725290149
D:\eclipse\JDK-1.9.0-159;9;0;0;64;true;1488421484000
D:\eclipse\JDK-1.9.0-158;9;0;0;64;true;1487817210000
C:\Program Files (x86)\Java\jdk1.8.0_101;1;8;0;32;true;1474379109487
C:\Program Files\Java\jre1.8.0_112;1;8;0;64;false;1483438827048
C:\Program Files\Java\jre1.8.0_111;1;8;0;64;false;1483438552670
C:\Program Files\Java\jre1.8.0_121;1;8;0;64;false;1490692628315
C:\Program Files\Java\jdk1.8.0_231\jre;1;8;0;64;false;1570274542000
C:\Program Files (x86)\Java\jre1.8.0_111;1;8;0;32;false;1483438528266
C:\Program Files\Java\jdk-11.0.5;11;0;5;64;true;1570362165000
C:\Program Files\Java\jdk1.8.0_121\jre;1;8;0;64;false;1490692583577
D:\eclipse\JDK-1.7.79;1;7;0;64;true;1428698969000
C:\Program Files\Java\jdk1.8.0_112\jre;1;8;0;64;false;1483438804453
Does this file exist on your system? What does it contain?
In the worst case, you can download of of the packages and unzip it (and hope that it finds the JRE/JDK):
Perhaps it's some type of encoding problem. Your \ don't look like \ on your command line...
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816738 is a reply to message #1816636] Wed, 06 November 2019 01:56 Go to previous messageGo to next message
Uninstall completely and installed it again. It will work
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816815 is a reply to message #1816636] Thu, 07 November 2019 09:44 Go to previous messageGo to next message
I tried to run eclipseinstaller (renamed eclipse.exe) using CMD and sadly error shows up AGAIN!
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816816 is a reply to message #1816815] Thu, 07 November 2019 09:58 Go to previous messageGo to next message
I finished to install. i used old version of installer (2019.03version) .
But most recent version of installer(2019.09) still deos not work.
Is this could be a bug that occours in some specipic environment?
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816822 is a reply to message #1816816] Thu, 07 November 2019 11:46 Go to previous messageGo to next message
I did indeed fix a problem today for how JAVA_HOME is processed.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=552784
That fix is in this version:
http://www.eclipse.org/downloads/download.php?file=/oomph/products/latest/eclipse-inst-win64.exe
I would very much appreciate it if you tried this version and let me know if that works
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816823 is a reply to message #1816822] Thu, 07 November 2019 12:13 Go to previous messageGo to next message
No. it does not work on my computer
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816825 is a reply to message #1816823] Thu, 07 November 2019 14:06 Go to previous messageGo to next message
Very strange. Could you run it from the command line as
eclipse-inst-win64.exe --debug
and share what's displayed on the console? Then I can see which Java executables that it finds and tests. It should find all the ones in the Windows registry, what's in JAVA_HOME, and what's on the PATH. It should test each one on the PATH, what's in JAVA_HOME, and each one in the registry, until it finds one that's at least a Java 1.8. Failing all those not validating, it will complain that it can't find one...
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816837 is a reply to message #1816825] Thu, 07 November 2019 20:52 Go to previous messageGo to next message
As you can see from the attached image, nothing is printed.
And still does not work.
But Error web page shows up...
  • Attachment: JAVAerror.png
    (Size: 10.76KB, Downloaded 394 times)
[Updated on: Thu, 07 November 2019 21:02] by Moderator
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816841 is a reply to message #1816837] Fri, 08 November 2019 01:35 Go to previous messageGo to next message
Looking at the C code of the latest version, this result seems almost impossible.
You're sure that Downloads contains just one version if eclipse-inst-win64.exe? Whenever I download a new version (with Firefox), I end up with a numbered version. E.g., my most recent download is eclipse-inst-win64(43).exe. So you're sure your Downloads doesn't contain a whole whack of such numbered versions such that you're not actually testing on the command line the most recently download version?
If you're sure you're testing the most recently downloaded version from the link I gave, will you be willing to help further, i.e., if I add more debug trace statements, to figure out where things are going wrong?
Because currently what you are describing suggests that the code doesn't just crash, but it really gets to the point of opening the browser link. So the code must have looked for javaw.exe in every folder on the PATH, and must of found none because there's no trace output from it testing any of JVMs, which also suggests that JAVA_HOME and the registry also did not find any folders to test. To understand why that's the happening, I'd really need more debug tracing, e.g., printing out every folder on the PATH that is tested for the presence of javaw.exe.
The native executable did change 2019-04 so it's possible that something newer is not working well for you... Mostly the support was for adding command line processing support and I changed the way command lines are launched to properly support "wide characters" to ensure that the command line can specify arbitrary unicode characters and that those arrive properly in the Java application...
Do you the default encoding on your OS?
I looked at this to see how that can be determined:
https://superuser.com/questions/670197/finding-out-the-default-character-encoding-in-windows
So I ran PowerShell and executed that:Quote:
Windows PowerShell
Copyright (C) 2009 Microsoft Corporation. All rights reserved.
PS C:\Users\merks> [System.Text.Encoding]::Default
IsSingleByte : True
BodyName : iso-8859-1
EncodingName : Western European (Windows)
HeaderName : Windows-1252
WebName : Windows-1252
WindowsCodePage : 1252
IsBrowserDisplay : True
IsBrowserSave : True
IsMailNewsDisplay : True
IsMailNewsSave : True
EncoderFallback : System.Text.InternalEncoderBestFitFallback
DecoderFallback : System.Text.InternalDecoderBestFitFallback
IsReadOnly : True
CodePage : 1252
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1816911 is a reply to message #1816841] Mon, 11 November 2019 12:02 Go to previous messageGo to next message
I am not good at English. so that I am not sure this answer is what you want. The file attached here is the output result of the command that you showed me.
(ps. I am Korean)
[Updated on: Mon, 11 November 2019 12:05] by Moderator
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1833561 is a reply to message #1816841] Sat, 17 October 2020 15:33 Go to previous messageGo to next message
I have the same Issue. I tried several JDK.
jdk 14.0.2
jdk 15
OpenJDK 11.0.8.10
Tested them one by one. Totally removing the others, resetting PAHT and JAVA_HOME variables, and restarted my Windows 10 (64bit) on every try.
I tried all the solutions from this thread. Non of them worked for me.
I attached a picture of the result of System.Text.Encoding command.
Please help! I need this IDE for work.
Re: Everythings perfect. But Eclipse installer can't install it for a reason that it can't find the [message #1833580 is a reply to message #1833561] Mon, 19 October 2020 02:30 Go to previous message
It's odd that you can have exactly the same problem with the latest version of the installer includes a JRE and should run even if you have no Java installed on your system.
But then the download page has the wrong links right now. :-(
https://bugs.eclipse.org/bugs/show_bug.cgi?id=567956
This version of the installer contains a JRE and should run anywhere:
https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2020-09/R/eclipse-inst-jre-win64.exe
You can always directly download a package instead:
Previous Topic:MQTT communication with S7-PLCs
Next Topic:How to use JDBC session for embedded jetty (Version above 9.4)?
Current Time: Sun Sep 21 18:40:54 EDT 2025
Powered by FUDForum. Page generated in 0.10632 seconds
