Home » Modeling » EMF » Run Eclipse Epsilon code generation online(How to run my epsilon code as a service on a server)
Run Eclipse Epsilon code generation online [message #1816848] Fri, 08 November 2019 04:34 Go to next message
Hi there!
I've been working on a code-generator in Eclipse Epsilon.
Everything works great, I have my models meta-models and templates. I can define models through Eclipse and run the transformation.
Now I want to create my models with an online drawing tool, click a button and generate code. For the drawing problem I will proced with a full custom solution but any suggestion is appreciated.
The real problem is the click and run thing. I'm trying to understand how to run my epsilon code as a service on a server.
I've read about eclipse headless but still I don't understand if this is the right direction.
Re: Run Eclipse Epsilon code generation online [message #1816859 is a reply to message #1816848] Fri, 08 November 2019 10:37 Go to previous message
It's probably best to post on the Epsilon forum:
https://www.eclipse.org/forums/index.php/f/22/
Previous Topic:Formatter2 - QualifiedName formatted with spaces between delimeter
Next Topic:Memory leak in Ecore application
Current Time: Sun Jul 20 20:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.06738 seconds
