Home » Newcomers » Newcomers » Unable to read repository
Unable to read repository [message #1816722] Tue, 05 November 2019 10:36 Go to next message
Fresh install of Eclipse IDE Version: Photon Release (4.8.0)
Build id: 20180619-1200
Unable to read repository error encountered while trying to download plugin or check for updates from the following repositories
www.flowable.org/designer/update
dowload.eclipse.org/releases/latest
download.eclipse.org/releases/photon
download.eclipse.org/eclipse/updates/4.8
Windows 7 running Java version 8 update 191
Re: Unable to read repository [message #1816735 is a reply to message #1816722] Wed, 06 November 2019 00:48 Go to previous messageGo to next message
Does it tell you which specific one doesn't load? Sometimes networks and servers have transient problems...
Re: Unable to read repository [message #1816812 is a reply to message #1816735] Thu, 07 November 2019 09:04 Go to previous messageGo to next message
It returns the unable to read repository error for all of them.
I have tried several times on different networks and its always the same
Re: Unable to read repository [message #1816842 is a reply to message #1816812] Fri, 08 November 2019 01:36 Go to previous messageGo to next message
Perhaps your firewall has blocked the Eclipse application from accessing the internet?
Re: Unable to read repository [message #1816843 is a reply to message #1816842] Fri, 08 November 2019 03:35 Go to previous messageGo to next message
I have been told this is not the case and the internal browser in eclipse can access them.
Could it be the version of Java?
Re: Unable to read repository [message #1816847 is a reply to message #1816843] Fri, 08 November 2019 04:18 Go to previous messageGo to next message
No, it seems unlikely to be the Java version. But it is possible that if you use https URs that the Java version might not have the root certificates needed to validate the secure connection.
There's nothing in the Error Log view that might provide clues? (Or in <workspace>/.metadata/.log).
Re: Unable to read repository [message #1816973 is a reply to message #1816847] Wed, 13 November 2019 03:42 Go to previous messageGo to next message
This is the log entry
!ENTRY org.eclipse.equinox.p2.core 4 0 2019-11-13 08:39:47.425
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://www.flowable.org/designer/update.
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:127)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:77)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.factoryLoad(ArtifactRepositoryManager.java:78)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:767)
at sun.reflect.GeneratedMethodAccessor52.invoke(Unknown Source)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:409)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:201)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Artifact.loadRepository(CachingRepositoryManager.java:543)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.basicRefreshRepository(AbstractRepositoryManager.java:203)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.refreshRepository(ArtifactRepositoryManager.java:121)
at org.eclipse.equinox.p2.ui.RepositoryManipulationPage.lambda$16(RepositoryManipulationPage.java:584)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Caused by: java.io.IOException: Invalid repository location: http://www.flowable.org/designer/update.
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepositoryFactory.load(SimpleArtifactRepositoryFactory.java:103)
... 14 more
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1002 2019-11-13 08:39:47.425
!MESSAGE Unable to read repository at http://www.flowable.org/designer/update.
!STACK 0
Re: Unable to read repository [message #1816974 is a reply to message #1816973] Wed, 13 November 2019 03:49 Go to previous messageGo to next message
Also logs say that System property http.proxyPort is not set as well as http.proxyHost, but i have completed the Proxy settings in the Network connections window in preferences
Re: Unable to read repository [message #1816993 is a reply to message #1816974] Wed, 13 November 2019 08:51 Go to previous messageGo to next message
I see such warnings from low-level libraries, but still everything works.
The particular stack suggests the problem at line 103 is currently at this line:
https://git.eclipse.org/c/equinox/rt.equinox.p2.git/tree/bundles/org.eclipse.equinox.p2.artifact.repository/src/org/eclipse/equinox/internal/p2/artifact/repository/simple/SimpleArtifactRepositoryFactory.java#n106
That suggests that the content.jar was downloaded but the contents could not be processed. This all works for me and the specific file https://www.flowable.org/designer/update/content.jar does exist and looks correct to me.
It all smells to me like something a virus scanner or firewall jar scanner would cause.
You could also have a look in your <home>/.eclipse/org.eclipse.oomph.p2/cache to see what if anything has made from the internet to your machine. You can delete this cache folder to see just is freshly and recently used files. The file names in the cache folder are mangled versions of the URL from which the file came. Are empty jars showing up here? Do _p2.index files appear? Do any files beyond just those appear?
Re: Unable to read repository [message #1819341 is a reply to message #1816993] Mon, 13 January 2020 09:07 Go to previous messageGo to next message
Hi Ed,
Sorry for the long down time on this.
Still trying to get this working. Looks like your correct in that its being blocked by a firewall.
Sorry i'm not a technical resource. Would be able to advise on how Eclipse is making this connection to pull down the jar file? Does it require certain ports to be open? any information would be really helpful.
Re: Unable to read repository [message #1819348 is a reply to message #1819341] Mon, 13 January 2020 10:21 Go to previous messageGo to next message
It's really just using http or https protocol with whatever ports those normally use. I'm really not sure what nitty gritty technical details in that regard could really help. Have you tried temporarily just disabling your virus scanner, firewall, and defender?
Re: Unable to read repository [message #1819383 is a reply to message #1819348] Tue, 14 January 2020 04:26 Go to previous messageGo to next message
Sadly I can't, i'm on the company network.
I have tried downloading the Flowable plugin and installing it manually but it still needs to contact sites for additional software (Graphiti (Incubation).
Do you know where this file can be sourced from?
Is it possible to install eclipse on a non-corporate machine, zip the eclipse files and use them on the corporate machine instead?
Re: Unable to read repository [message #1819446 is a reply to message #1819383] Wed, 15 January 2020 09:09 Go to previous messageGo to next message
It is possible to create a mirror of a repository:
https://wiki.eclipse.org/Equinox_p2_Repository_Mirroring
Re: Unable to read repository [message #1852032 is a reply to message #1816722] Tue, 26 April 2022 10:25 Go to previous message
I had similar problems. What solved them for me was downloading new security certificates for Java. That is, I replaced the cacerts file with one from my company.
C:\Program Files\Java\jdk1.8.0_321\jre\lib\security\cacerts
Previous Topic:disappearing buttons
Next Topic:Eclipse Plugin Issue
Current Time: Mon Sep 22 13:38:25 EDT 2025
Powered by FUDForum. Page generated in 0.14543 seconds
