Home » Eclipse Projects » Sirius » Java services(Java services are invoked twice)
Java services [message #1816701] Tue, 05 November 2019 05:49 Go to next message
Hello Team,
We are calling Java service for data computation.
While debugging we noticed that service method are called twice once during representation creation and second while opening the diagram.
This will impact performance for complex diagrams.
Can this be avoided ?
Thank you.
Rakesh
Re: Java services [message #1816713 is a reply to message #1816701] Tue, 05 November 2019 07:41 Go to previous messageGo to next message
Hi Rakesh,
Could you precise in which interpreted expression do you use this service ?
Note that semanticCandidates, preconditions and others expression on the mappings are evaluated on all refreshes of the diagram.
Regarding how you want to manipulate your data, you might choose to disable the automatic refresh and refresh at opening and then let users manually refresh the diagrams.
You could also check if you need to call this service on each refresh (when your data is supposed to change, need this computation ? ) and put this service as a specific step of the diagram creation tools .
You might also nee to take a look to the different synchronization modes of the mappings described in https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#graphical_elements
You might also choose to call your service in the model operation that you can add a direct children of the DiagramDescription and which be called only once at creation time.
Re: Java services [message #1816744 is a reply to message #1816713] Wed, 06 November 2019 04:00 Go to previous message
Hello Maxime,
Thank you for your response.
We are facing this for semantic candidates expressions.
Since these expressions are used to compute data for nodes , its fine to invoke these on refresh or while creating representation.
But I think invoking these twice once during representation creation and second while opening the editor is not required.
Rakesh
Previous Topic:SIRIUS AND XML
Next Topic:Update palette dynamically
Current Time: Sat Jul 26 00:23:43 EDT 2025
Powered by FUDForum. Page generated in 0.03590 seconds
