Home » Modeling » TMF (Xtext) » Check if a language/grammar file is defined twice in Workspace (Validation for language files defined twice)
Check if a language/grammar file is defined twice in Workspace [message #1816430] Tue, 29 October 2019 08:36 Go to next message
We have a Visual Studio Code language extension written in Xtext. We need to make sure that certain grammar files (with certain extensions) are defined only once inside the workspace, and if not show a validation error.
Is there perhaps an easy way to do this with XText?
Thanks a lot
[Updated on: Tue, 29 October 2019 08:37] by Moderator
Re: Check if a language/grammar file is defined twice in Workspace [message #1816627 is a reply to message #1816430] Fri, 01 November 2019 13:58 Go to previous messageGo to next message
hi, i am not sure if i get your problem
what makes a file "defined twice"
you do you mean something like:
there should be only one
"Hello World!" in all mydsl files in the project?
Re: Check if a language/grammar file is defined twice in Workspace [message #1816637 is a reply to message #1816627] Sat, 02 November 2019 03:33 Go to previous message
This is a job for the validator.
Lorenzo Bettini found a very simple to understand implementation
Source: https://github.com/LorenzoBettini/packtpub-xtext-book-examples/blob/master/org.example.smalljava/src/org/example/smalljava/validation/SmallJavaValidator.xtend
@Check
def void checkNoDuplicateMember(SJMember member) {
val duplicate = member.containingClass.members.findFirst[
it != member && it.eClass == member.eClass &&
it.name == member.name
if (duplicate != null)
error("Duplicate member '" + member.name + "'",
SmallJavaPackage::eINSTANCE.SJMember_Name,
DUPLICATE_ELEMENT
HIH, Uli
Previous Topic:Operator overloading in Xbase Expression
Next Topic:Xtend Grey Space: It works great until it doesn't
Current Time: Mon Jul 21 02:23:07 EDT 2025
Powered by FUDForum. Page generated in 0.06298 seconds
