OCL XText Console not available in Eclipse 2019-09 [message #1816407] |
Tue, 29 October 2019 03:17  |
I've tried with a simple model (Library from tutorial). I have generated the Model, Edit and Editor code from .genmodel keeping defaults, started a new Eclipse instance with Run as Java Application, created an instance Library using the Example EMF Model Creation Wizard.
Using Eclipse 2019-06, when I right-click on the resource or one of its element, the OCL submenu with its Show Xtext OCL Console is available. I don't find it anymore with Eclipse 2019-09.
I have double-check that OCL pivot and Text are installed. In the configuration tab of Installation details, I have :
org.eclipse.ocl.examples.xtext.console (4.9.0.v20190910-0937) "OCL Examples Xtext Console and Interpreter" [Starting]
Any hint about what may be missing in my Eclipse 2019-09 installation ?
Dominique
Re: OCL XText Console not available in Eclipse 2019-09 [message #1816531 is a reply to message #1816414] |
Wed, 30 October 2019 11:25   |
Hi Ed,
Thanks for the reply.
I have investigate the problem, here are some elements.
I will call EclipseMain the Eclipse used to develop the EMF plugin and EclipseChild the one launched from EclipseMain to run the plugin.
To narrow down the 'impossibility' a bit
- open an Ecore file in the Sample Ecore Model Editor and see how much of the OCL submenu is present with that editor.
OCL submenu is available both in EclipseMain and EclipseChild.
- post your model and metamodel(s) so that it can be opened on another Eclipse installation
- close all projects then create a trivial EMF project and see if that works.
Simple.zip contains a very simple Ecore model with the generated Model, Edit and Editor plugins.
I import this archive in a newly created workspace with EclipseMain.
SimpleTest.zip contains a minimal Simple model, I import it in a new workspace with EclipseChild.
With Eclipse 2019-06, the OCL submenu is available in EclipseChild when I right-click on the open resource. With Eclipse 2019-09, it is not.
I have found a change in org.eclipse.ui.internal.PopupMenuExtender.createModelFor() :
- in Eclipse 2019-06, to find if an existing menuModel is available,"popup" is looked for in the tag.
- in Eclipse 2019-09, ContributionsAnalyzer.MC_POPUP is looked for, which is "menuContribution:popup".
If I change back the string to "popup", the OCL submenu is then available in Eclipse 2019-09.
I have no conclusion about this, but may be someone can reproduce the problem with the information given.
Dominique
Attachment: Simple.zip
(Size: 118.32KB, Downloaded 146 times)
Attachment: SimpleTest.zip
(Size: 0.52KB, Downloaded 161 times)
FUDForum. Page generated in 0.04092 seconds
