Home » Newcomers » Newcomers » Eclipse Mars.2 Display Issue(Eclipse Mars.2 Display Issue - Need Help)
Eclipse Mars.2 Display Issue [message #1816240] Thu, 24 October 2019 10:51 Go to next message
Hi there,
I am not a newcomer as such, I have been using Eclipse for around 12 years and this is the first time I have come across this issue and despite trying everything (apart from a reinstall) I have come on here for your help please.
As you can see from the screenshot images I have uploaded I have lost all the .drl files for each of the folders where I build the jar files. They should be displayed along with the xml files and the version.properties file. The drl files are in the workspace so that's ok, but I have to use windows explorer to open each file individually.
Also, the main window is blank when it should contain the .drl files? All I can do is minimise or maximise this blank window? I have no way of closing this down?
Something must have happened but I've no idea what exactly.
Hope you can help!
Thanks, Marcus
Re: Eclipse Mars.2 Display Issue [message #1816246 is a reply to message #1816240] Thu, 24 October 2019 11:29 Go to previous message
Thanks but after posting this the solution became apparent - refreshing the project resolved it! I tried rebuilding / cleaning you name it but I didn't think to refresh the project!
Previous Topic:Hover when code isn't selected
Next Topic:Eclipse
Current Time: Sun Jul 20 21:25:36 EDT 2025
Powered by FUDForum. Page generated in 0.11169 seconds
