Home » Modeling » TMF (Xtext) » Refactoring command with custom Refactor class fails(Implemented refactor classes like in xtext source for extractvariable but handler doesn't get executed)
Refactoring command with custom Refactor class fails [message #1815926] Tue, 15 October 2019 07:09 Go to next message
Hi all,
I need some advice in implementing a refactoring action for my DSL based files.
My goal is to implement an extraction command which extracts the selected lines of the editor into another file.
I found the ExtractVariable command in the xtext sources and tried to implement something similar. (org.eclipse.xtext.xbase.ui.refactoring.ExtractVariableHandler)
There the ExtractVariableHandler makes use of ExtractVariableRefactoring.
I also created such a handler making use of my custom refactoring action.
Once I trigger the refactoring action from the menu nothing happens.
The ExtractVariableHandler class makes use of a refactoringProvider which is a
Provider<ExtractVariableRefactoring> object.
In my case I changed that to Provider<MyDslExtractRefactoring>, but then the handler isn't triggered anymore.
Once I set the class of my refactoring provider to anything else like Provider<ExtractVariableRefactoring> the execute() method of the handler is triggered.
Is it necessary to register or inject that Refactoring close anywhere else?
In my plugin.xml I introduced the handler only.
Thanks in advance!
best regards,
Martin
Re: Refactoring command with custom Refactor class fails [message #1815927 is a reply to message #1815926] Tue, 15 October 2019 07:12 Go to previous messageGo to next message
How does your plugin.xml look like
Do you make correct use of yourdslexecutableextensionfactory
Did you debug for exceptions
Re: Refactoring command with custom Refactor class fails [message #1815936 is a reply to message #1815927] Tue, 15 October 2019 09:20 Go to previous messageGo to next message
Hi Christian,
thanks for your fast reply.
I couldn't find any exceptions yet.
In the plugin.xml I have just added the handler for now:
<!-- Introduce Create DR Refactoring -->
<extension point="org.eclipse.ui.handlers">
<handler
class="de.test.dsl.ui.MyDslExecutableExtensionFactory:de.test.dsl.ui.refactoring.ExtractDrHandler"
commandId="de.test.dsl.ui.refactoring.ExtractDrHandler">
<activeWhen>
<reference
definitionId="de.test.dsl.mydsl.Editor.opened">
</reference>
</activeWhen>
</handler>
</extension>
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:#TextEditorContext?after=group.edit">
<command commandId="de.test.dsl.ui.refactoring.ExtractDrHandler"
style="push">
<visibleWhen checkEnabled="false">
<reference
</reference>
</visibleWhen>
</command>
</menuContribution>
</extension>
<!-- TODO -->
Then I created the class "de.test.dsl.ui.refactoring.ExtractDrHandler"
There I added this member:
@Inject
private Provider<ExtractDrRefactoring> refactoringProvider;
The other members are just a copy of the ExtractVariableHandler.
Then I created the class "de.test.dsl.ui.refactoring.ExtractDrRefactoring".
It extends the Refactoring class and is a copy of ExtractVariableRefactoring.
I can see the popup entry in the menu but clicking doesn't do anything.
I also cannot debug to the handler as it seems that the handler is never reached.
Thanks again!
best regards,
Martin
Re: Refactoring command with custom Refactor class fails [message #1815938 is a reply to message #1815936] Tue, 15 October 2019 10:21 Go to previous messageGo to next message
so if you debug your handler wont stop?
you may also have a look at
https://dietrich-it.de/xtext/2011/10/15/xtext-calling-the-generator-from-a-context-menu.html
Re: Refactoring command with custom Refactor class fails [message #1815941 is a reply to message #1815938] Tue, 15 October 2019 11:08 Go to previous message
Hi Christian,
thanks for your efforts and the link.
I have re-implemented the handler and the refactoring class and now it's working.
At the beginning I copied all members from the ExtractVariable and the also the RenameHandler to my file.
Now I tried to use the required steps only.
Perhaps some of those injection commands failed there.
Martin
Previous Topic:Disable NodeModel
Next Topic:generateTracedFile is undefined for the type IFileSystemAccess2
Current Time: Mon Jul 21 01:48:02 EDT 2025
Powered by FUDForum. Page generated in 0.06503 seconds
