Development of a UI with EMF forms without a data model [message #1815906] |
Mon, 14 October 2019 21:36  |
Hi there!
I'm a beginner in EMF and, as far as I know, the normal course of action, when developing a UI with EMF forms, is to render both data model (say, in UML) and EMF's view model.
I'm wondering whether I could develop a UI with EMF forms without a data model, actually, I'd like to generate a data model from such a UI...Is it possible? If so, links to detailed information or examples would be highly appreciated.
Thank you for your attention.
Clever.
Re: Development of a UI with EMF forms without a data model [message #1816041 is a reply to message #1816004] |
Thu, 17 October 2019 18:39  |
Thank you for your reply, Ed!
"In the simplest form, you can transform to EOperations with a "GenModel" body annotation which will generate the Java code in that annotation into the body of the correspondingly generate Java operation" => This apparently suits me best...Would you have a URL with an example?
At a later project phase, I aim to use JET to parse through the XML instance output, but I may not have enough time for that...would it make sense?
Clever.
FUDForum. Page generated in 0.28912 seconds
