Testing of AUT launched from another AUT [message #1815720] |
Tue, 08 October 2019 16:17 |
We test an AUT which is opened by another AUT.
The parent AUT works fine and can be tested.
But the child AUT shows up as connected in the left window. But when we try to perform the Object Modelling for this AUT we are getting the error as shown below
Both AUTs are swing based. Has anyone done this with Jubula?
I have also started the AUT agent in "lenient" mode does not work.
2019-10-08 15:44:05.035 [Connection.ReaderThread:Socket[addr=/127.0.0.1,port=64530,localport=60001]] ERROR o.e.j.c.internal.Communicator - caught exception from 'org.eclipse.jubula.autagent.common.commands.ConnectToAutCommand.execute()'
java.lang.NullPointerException: null
at org.eclipse.jubula.autagent.common.agent.AutAgent.sendConnectToClientMessage(AutAgent.java:709) ~[na:na]
at org.eclipse.jubula.autagent.common.commands.ConnectToAutCommand.execute(ConnectToAutCommand.java:46) ~[na:na]
at org.eclipse.jubula.communication.internal.Communicator$ConnectionListener.received(Communicator.java:921) ~[org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.fireMessageReceived(Connection.java:402) [org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection.access$2(Connection.java:391) [org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
at org.eclipse.jubula.communication.internal.connection.Connection$ReaderThread.run(Connection.java:454) [org.eclipse.jubula.communication_4.0.0.201902270829.jar:na]
2019-10-08 15:44:15.061 [Awaiting command: class org.eclipse.jubula.client.internal.commands.ConnectToAutResponseCommand] WARN o.e.j.c.i.c.ConnectToAutResponseCommand - org.eclipse.jubula.client.internal.commands.ConnectToAutResponseCommandtimeout() called
2019-10-08 15:44:25.062 [Worker-54: Start Object Mapping Mode] ERROR o.e.j.c.c.c.AUTConnection - Connection to AUT could not be established.
FUDForum. Page generated in 0.02549 seconds
