WAR validation failure -- but it has no effect [message #181572] |
Thu, 12 October 2006 13:57  |
I'm getting the an error reported in problems view when I build my dynamic
web project using the web.xml shown below.
If I click on the error message, eclipse ignores the click and does not
activate the web.xml file. There are no errors flaged in the web.xml
editor, and the project deploys and executes correctly.
If everything works well, why am I getting this error?
Michael Giroux
CHKJ3000E: WAR Validation Failed:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.De ploymentDescriptorLoadException:
WEB-INF/web.xml TestProjectEJB3 Unknown 1160675451248 1169732
<web-app id="WebApp_ID" version="2.4"
xmlns="http://java.sun.com/xml/ns/j2ee"
xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
<display-name>TestProjectEJB3</display-name>
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value> classpath:/com/bull/test/services-generationtestproject-cont ext.xml,
classpath:/com/bull/test/config-context.xml</param-value>
</context-param>
<!-- Listener, that does all the startup work (configuration, init). -->
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener </listener-class>
</listener>
<servlet>
<description>Test for the EJB3 business code</description>
<display-name>TestServlet</display-name>
<servlet-name>TestServlet</servlet-name>
<servlet-class>com.bull.test.TestServlet</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/TestServlet</url-pattern>
</servlet-mapping>
</web-app>
Re: WAR validation failure -- but it has no effect [message #181653 is a reply to message #181643] |
Fri, 13 October 2006 11:39  |
Eclipse 3.2.1 + WTP 1.5.1
1. I'm including the exceptions that were thrown.
2. I created a new workspace and imported the project using the "copy
files" option. The new project did not have the error.
3. Guessing there might be something wrong in the original workspace, I went
back to the original workspace and did the following:
a. rename web.xml to w.x
b.build the project
c. rename w.x to web.xml
d build the project
Following this sequence, the error has been eliminated. I did not make any
changes to web.xml other than to rename it. My guess is that renaming it
cleared something that was being cached.
Michael Giroux
!ENTRY org.eclipse.wst.validation 4 0 2006-10-12 11:06:26.626
!MESSAGE
*** ERROR ***: Thu Oct 12 11:06:26 GMT-07:00 2006
org.eclipse.wst.validation.internal.core.ValidationException : CHKJ3000E: WAR
Validation Failed:
WEB-INF/web.xml
at
org.eclipse.jst.j2ee.model.internal.validation.WarValidator. validateInJob(WarValidator.java:295)
at
org.eclipse.jst.j2ee.internal.web.validation.UIWarValidator. validateInJob(UIWarValidator.java:92)
at
org.eclipse.wst.validation.internal.operations.ValidatorJob. run(ValidatorJob.java:70)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.wst.validation 4 0 2006-10-12 11:06:26.642
!MESSAGE
WEB-INF/web.xml
Stack trace of nested exception:
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:357)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
at
org.eclipse.wst.common.internal.emfworkbench.WorkbenchResour ceHelper.getOrCreateResource(WorkbenchResourceHelper.java:38 4)
at
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getResource(EditModel.java:680)
at
org.eclipse.wst.common.componentcore.internal.ArtifactEditMo del.getResource(ArtifactEditModel.java:174)
at
org.eclipse.wst.common.componentcore.ArtifactEdit.getResourc e(ArtifactEdit.java:636)
at
org.eclipse.jst.j2ee.internal.archive.operations.ComponentLo adStrategyImpl.getMofResource(ComponentLoadStrategyImpl.java :467)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.Archive Impl.getMofResource(ArchiveImpl.java:731)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.ModuleF ileImpl.getDeploymentDescriptorResource(ModuleFileImpl.java: 61)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.Xml BasedImportStrategyImpl.primLoadDeploymentDescriptor(XmlBase dImportStrategyImpl.java:39)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.War 22ImportStrategyImpl.loadDeploymentDescriptor(War22ImportStr ategyImpl.java:87)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.strategy.War 22ImportStrategyImpl.importMetaData(War22ImportStrategyImpl. java:81)
at
org.eclipse.jst.j2ee.commonarchivecore.internal.impl.WARFile Impl.getDeploymentDescriptor(WARFileImpl.java:145)
at
org.eclipse.jst.j2ee.model.internal.validation.WarValidator. validateInJob(WarValidator.java:280)
at
at
FUDForum. Page generated in 0.04904 seconds
