Home » Eclipse Projects » Kura » Kura WatchDog
Kura WatchDog [message #1815364] Tue, 01 October 2019 08:55 Go to next message
Hi guys, i tried the kura watchdog to check if after a number of connection attempts to the broker, the watchdog restarted the gateway. In fact this mechanism works. I wanted to know if the watchdog could work in the following case: the kura process remains active in the system but it is faked (the log no longer grows and does not publish and does not perform any functionality). In your opinion, in this case, using the watchdog, can I see that kura needs to be restarted? Or, given that the kura service remains apparently active, does the watchdog not notice anything?
Re: Kura WatchDog [message #1815367 is a reply to message #1815364] Tue, 01 October 2019 09:08 Go to previous messageGo to next message
If the process registers itself in the watchdog and stops pinging it, the system will be rebooted
Re: Kura WatchDog [message #1815390 is a reply to message #1815367] Wed, 02 October 2019 03:47 Go to previous messageGo to next message
Thank you. In order for the watchdog to work with my component I have to implement in the component the CriticalComponent interface right?
Re: Kura WatchDog [message #1815393 is a reply to message #1815390] Wed, 02 October 2019 04:16 Go to previous message
yes
Previous Topic:Wire Math Singleport Components and "Missing operand" error
Next Topic:Eclipse Kura Bundle project with Maven
Current Time: Mon Jul 21 09:48:11 EDT 2025
Powered by FUDForum. Page generated in 0.03618 seconds
